Author Topic: HOW TO AKE RADIATORS FANS WORK CONTINUOSLY  (Read 2793 times)
aymen
  • syria
« on: 06 February 2010, 11:21:12 »
HI,
PLS. ANY GENTLE TELLS ME HOW TO MAKE FANS WORK CONTIUOSLY. OR TO WORK WHEN TEMP. IS 90 c.
THANKS,
AYMEN
Re: HOW TO AKE RADIATORS FANS WORK CONTINUOSLY
« Reply #1 on: 06 February 2010, 11:53:41 »
What temp do your fans come on then?  Low speed fans should come on at just above midpoint on gauge (so around 96C on prefacelift, 92C on facelifts)
hoodjam
  • Norfolk
« Reply #2 on: 08 February 2010, 13:19:25 »
Hi - Just curious but why higher temperature on pre-facelifts (which I have), and if beneficial, what needs to be done to get the fans on sooner.
Thanks
« Reply #3 on: 08 February 2010, 13:39:14 »
Thanks
Facelifts and prefacelifts actually run at the same temp (if you check with specialist equipment).  The markings on the gauge are in no way even close to accurate, particularly on the prefacelift - they are purely a guide.
The gauge is heavily biased to keep the needle around midpoint on the gauge - for example, on a prefacelift, that bit between 92C and 98C actually covers from around 85C to 110C in reality, as is subject to a 12s delayed average, so as to keep the needle stable, even if the true temp peaks and troughs...
« Reply #4 on: 08 February 2010, 17:22:11 »
Yep. Don't know why they put numbers on the gauge as they bear little relation to reality.
Mrs. KW's MX 5 is even worse though. Gauge is fed from an output on the engine ECU. I swear it has 3 positions. Cold, Normal and "oh, sh!t!".
A couple of minutes after starting it gradually moves from cold to normal. You can mimble around, sit in traffic or give it a total beasting and it won't move from normal, until about 30s before the rad. cap pops, whereby it moves to the "oh, sh!t!" position.
« Reply #5 on: 08 February 2010, 18:46:27 »
My mum's 3 series is like that.
hoodjam
  • Norfolk
« Reply #6 on: 09 February 2010, 10:05:14 »
Thanks for the info
jay69
  • sheffield
« Reply #7 on: 11 February 2010, 17:47:56 »
HI,
THANKS,
AYMEN
are you wantin to know how to wire the fans up so there running all the time from start up till finish or just come on when temp gets to 90c ?
51 plate omega elite 2.6 v6
aymen
  • syria
« Reply #8 on: 15 February 2010, 12:16:05 »
in fact as this matter made me very confused, yesterday I went to an electrician, he connected the two wires on the the upper sensor of the rad. , now the tempeture does not get more than 94, the fans are working continuously in slow rotation, that is well.
thank  you all.
« Reply #9 on: 15 February 2010, 12:31:34 »
Exactly like my old rover 214  ;D
« Reply #10 on: 15 February 2010, 12:47:58 »
If it was anything like mine it should have been labelled "Replace Head Gasket Soon" instead. ;D
