Author Topic: heater blowing luke warm  (Read 3727 times)
Dai
  • Manchester
« on: 11 February 2010, 07:42:01 »
My fans are working OK but even on max heat the air is only luke warm. The temp reading on the dash is about 20 degrees above actual temperature. Is this coincidence or are the 2 connected? Car is a 98 MV6.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: heater blowing luke warm
« Reply #1 on: 11 February 2010, 07:47:07 »
sounds like you may need to back flush your heater rad. :y
    • E250 Est / Elroq
« Reply #2 on: 11 February 2010, 08:16:48 »
If the car temp itself isnt rising to midpoint on the guage, then sounds like thermostat.
if it is, then flush the heater matrix as a 1st port of call, check the maint section for a how to  :y
  • Auckland
    • Mazda MPV
« Reply #3 on: 14 February 2010, 13:32:43 »
I think I read somewhere that the climate system uses the outside temperature somehow.
A faulty outside temperature sensor could therefore confuse the climate system. (not sure if this applies to mini-facelift as well as facelift).
I think the outside sensors are cheap & easy to replace so it would make sense to change that first before pulling the heating & cooling systems apart.
Mr.Salvador
« Reply #4 on: 18 February 2010, 15:14:28 »
mine is doing something similar. Im about to fit a new water pump as i think this is the problem. try that
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #5 on: 18 February 2010, 22:01:58 »
Just posted a similar thread... my dash is saying 68 degrees, and the heater is blowing cold air... the climate control does rely on the outside temperature sensor. £3.85 from AutoVaux.... :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
Sad
  • Dorset
    • VW Golf
« Reply #6 on: 22 February 2010, 11:16:19 »
I'm aware that the 'sampling fan' not working can affect the heater:
http://www.omegaowners.com/forum/YaBB.pl?num=1162120610
HTH    :y
