Author Topic: DVD headrests  (Read 5018 times)
Dave Elite
  • Ellesmere Port
DVD headrests
« on: 15 March 2010, 11:55:31 »
Hello, I'm going to put some dvd headrests in the mig to keep the kids happy on long trips. They are in the wifes Vectra at the moment and I have them pluged into a 40a emty fuse socket in the boot. Can anyone sugest a good place to plug in the headrests in the omega? I dont want to use the cig lighter in the back because the dvd will go off every time I turn the engine off. Thanks for any help :y
    • E250 Est / Elroq
Re: DVD headrests
« Reply #1 on: 15 March 2010, 12:03:53 »
[movedhere] Omega General Help [move by] Jimbob.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: DVD headrests
« Reply #2 on: 15 March 2010, 12:13:12 »
Always adviseable to connect via an ignition switched supply to ensure that when the keys are out, the system is dead and cannot inadvertantly drain the battery.
Radio & Decoding Technician
www.dndservices.co.uk
Dave Elite
  • Ellesmere Port
Re: DVD headrests
« Reply #3 on: 15 March 2010, 12:40:57 »
I'd always turn the dvds off. Can you sugest a permenant live i could use?
Re: DVD headrests
« Reply #4 on: 15 March 2010, 13:00:34 »
Easy enough to run a cable from battery (with a fusible link) back to where you want it with a suitable connector at the outlet
Dave Elite
  • Ellesmere Port
Re: DVD headrests
« Reply #5 on: 15 March 2010, 13:30:26 »
Thanks might try that unless anylone else has any sugestions?
Re: DVD headrests
« Reply #6 on: 15 March 2010, 15:59:29 »
Believe me mate when I say use the 12v socket between the seats! I also said 'I always turn them off' until I forgot!, if the ignition timer hadn't turned them off, i'd have been left stranded. :y
Sixstring
  • Lydney, Gloucestershire
Re: DVD headrests
« Reply #7 on: 15 March 2010, 16:03:20 »
I have a single dvd  screen in between the seats for the kids in the rear, and have forgotten to turn them off twice now on a sunday, resulting in reluctant starting first thing monday morning for work!!!!!
GOTTA be ign controlled, mine are now wired via fuse from the rear lighter skt.
Nuff said.
Dave Elite
  • Ellesmere Port
Re: DVD headrests
« Reply #8 on: 15 March 2010, 16:37:37 »
The headrests have been in my wifes vectra for two years and we've never forgot. I just want to know if somone knows of a perminent live I could use on the omega?
Sixstring
Re: DVD headrests
« Reply #9 on: 15 March 2010, 16:51:13 »
OK, well I would run a cable (fused, of course at 7.5A) and take it from the fusebox via a grommet. i would also take a negative (earth wire) from the earth block too, and make sure you run them under the L/H sills and then under the carpet (use a welding rod or coathanger to feed it) to a plug skt (maplins 12v marked up) drilled underneath the lighter skt.
hope this helps.
Mike.
Dave Elite
  • Ellesmere Port
Re: DVD headrests
« Reply #10 on: 16 March 2010, 17:05:43 »
I've done it know. I used the towbar permanent live in the boot. thanks for the advice. Dave
Re: DVD headrests
« Reply #11 on: 16 March 2010, 17:28:29 »
Turned off doesn't necessarily mean they are consuming no current. ;)
Dave Elite
  • Ellesmere Port
Re: DVD headrests
« Reply #12 on: 16 March 2010, 17:36:31 »
I'll see how it is in the morning. They where always ok in the wifes car. Thanks for the warning though.
