Brake Light Issue
Started by MAMS, 31 March 2010, 13:46:39
MAMS
Hey folks, got a wee issue with my brake lights...
basically the wee one top of the rear window is working fine but the 2 rear of the car are not.
I simply assumed blown bulbs but on checking i can't see any seperate brake bulbs so assume the rear lights work as the brake lights????
they work fine as rear lights though so stuck as to where to start looking.
this on a 2l x plate facelift auto saloon
any pointers as to where to start looking would be most appreciated.
"Why am i always surrounded by frikkin Idiots" - Dr Evil
Stop lamps are on the quarterpanels, seperate bulbs
MAMS
ok sounds like i maybe am being stupid then.... where's the quarterpanels?
Welung666
Quoteok sounds like i maybe am being stupid then.... where's the quarterpanels?
The bits of the back light that sit still when you open the boot ;)  :P
Light units NOT on the bootlid are on the rear quarterpanels ;)
;D ;D ;D ;D ;D
MAMS
ok right looked in there, and when i bring the bit out there are only 2 bulbs on it top being the indicator, bottom being the tail lights, do i need to look further in for the brake bulb?
#7
Bottom one, combined stop/tail. Twin filament
MAMS
ok right bottom one works fine when tail lights switched on, but does NOTHING when brake depressed.
Has it got two filaments in. If yes, change the bulb for a decent make. If no, replace with correct type
MAMS
ok will go look then pop to the local suppliers :)
assuming that if the top brake light works that should and they don't run off seperate switches etc
Quoteok will go look then pop to the local suppliers :)
Nope
MAMS
FIXED, many thanks guys, especially Rob :)
new bulbs costing the handsome amount of £1.99 for the 2 in the local autoparts and all is good again... i genuinely thought i was going loopy at one point lol :)
Thanks
neilr
im surprised you didnt get message on display to check bulbs
MAMS
Quoteim surprised you didnt get message on display to check bulbs
i have display issues at the moment lol so that's why i didn't get that ;)
