Cruise Control Question
Started by Simon72, 01 April 2010, 21:56:53
Simon72
I hopefully will be fitting Cruise control to my Omega over this weekend and will be having it enabled if needed by a kind man around the corner of me with TECH2.
Now the question I have after looking through the owners manual is....
IS THERE AN INDICATION LIGHT ON THE DASH THAT COMES ON WHEN CRUISE IS ACTIVE??
On a few of my previous cars a light would come on to show you have it working.
Also does it IMPROVE or DECREASE the fuel economy when used on an Omega??
Cheers
Simon
no light on the dash or mid to say its enabled, you will know anyway cause you pressed the button.
It makes mpg worse, why? When you reach a hill, your foot tends to stay in same place, and your speed will fall 5-10 mph say, cruise will always keep you at the same speed no matter what. Over the course of a long run i would say your better off without it if your after mpg, but i am lazy and use it all the time
jonny2112
It's not so bad when you go up the hill, but I hate the way it slows down when you descend on the other side!
Broomies Mate
Quoteno light on the dash or mid to say its enabled, you will know anyway cause you pressed the button.
^^ Spot on.
No light, and worse MPG due to a pretty basic algorhythm used.
QuoteNo light, and worse MPG due to a pretty basic algorhythm used.
Problem is, sheer boredom on motorway journeys does tend to make me heavy footed when there's no need. ::) I find cruise does away with that.
In fact, I did a run around the bottom half of the M25 and into Kent earlier in the week (quite a few hills) and experimented with cruise one way and without the other. I found I couldn't match it for MPG. I guess cruise tends to keep you at a constant speed, and you find a route through the traffic that maintains it. Without cruise, I tend not to maintain a very constant speed in traffic, and that hurts consumption.
Using cruise below about 55-60 MPH is a joke, because it causes too many downshifts on an auto, which would have been avoidable with manual throttle.
i agree entirely.
My assumption was based on a human sticking to 70, and cruise sticking to 70 ::)
