Author Topic: ccr2006 not tuning in or finding stations,  (Read 2843 times)
dmg746
« on: 25 March 2010, 14:20:23 »
just purchursed a 2003 omega dti elite, when you put the radio on i cant find new stations, it just carries on searching. its is the ccr2006 unit if that helps and when switched on it says bose sound
« Last Edit: 25 March 2010, 20:07:35 by dmg746 »
  • Auckland
    • Mazda MPV
Re: ccr2006 not tuning in or finding stations,
« Reply #1 on: 25 March 2010, 21:46:40 »
Most likely a break in the aerial lead or possibly a fault with the aerial amplifier under the fibre parcel shelf.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 26 March 2010, 09:19:26 »
And to narrow down that excellent diagnosis still further, its usually either the connections between the aerial amp and the screen, or the centre core of the right angled connector at the rear of the head unit
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #3 on: 26 March 2010, 09:31:11 »
If some heavy handed idiot had the headunit out before you bought it, this is probably the cause !!  There is very little room in there and the unit needs "teasing" back in carefully .. not just ramming in and hoping ... which is what too many do .. and they break things ...  >:( >:( >:( >:(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 26 March 2010, 09:34:22 »
Not just when refitting, often damaged if the cage comes out at the same time as the radio
dmg746
« Reply #5 on: 27 March 2010, 08:28:50 »
thanks for you are imputs lads, will check and let u know, oh and i never said but its an estate if that makes a difference,
« Last Edit: 27 March 2010, 08:30:37 by dmg746 »
  • Auckland
    • Mazda MPV
« Reply #6 on: 27 March 2010, 08:46:00 »
It does make a difference, the estate doesn't use the rear screen heater element as an aerial so it doesn't have the same aerial amplifier. I don't have an estate and I can't remember whether it uses a roof aerial or elements in one of the rear side windows :-/
dmg746
« Reply #7 on: 27 March 2010, 08:48:22 »
it has an aerial on the roof
Welung666
« Reply #8 on: 27 March 2010, 08:49:26 »
Roof ariel on an estate. Most likely is the 90 degree out of the back of the cage. Not sure if you're local to me but I'd give you a hand/show you if you are.
dmg746
« Reply #9 on: 06 April 2010, 13:02:01 »
the problem was with the aerial base, basically the solder had come away from the amplifier inside. done a tempory fix but really need a new 1. so if any one has an aerial base in good working order for an omega elite estate. has to be the base with the rotating ball on it as so the aerial doesnt hit the spoiler then ill buy it. :)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 08 April 2010, 09:02:47 »
If looking at aftermarket beesting aerials, the one for the Audi A4 Avant is more "upright" to prevent from hitting the tailgates. I mention this as they are generally more widely available and listed than the Omega ones
dmg746
« Reply #11 on: 09 April 2010, 13:16:51 »
its not just the aerial its the base as well. oh and it will need an amplifier in it
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 09 April 2010, 13:33:18 »
Thats why I suggested the Audi A4 Avant, the base also has the same amp inside
