Author Topic: intermittant indicators  (Read 2524 times)
gsdtrainer
  • newport,s.wales
« on: 03 May 2010, 16:39:05 »
funny one.indicator problem.works ok sometimes,but most of the time back bulbs not working.front and side work ok ,but flash fast as if bulb gone,and hazards work perfectly with all lights working,but both rears not flashing when indicating .checked wiring and connections.relay clicking,but not sure if working correct.any ideas most welcome. :( :-/
    • E250 Est / Elroq
Re: intermittant indicators
« Reply #1 on: 03 May 2010, 16:42:49 »
activate the hazzard switch 20 or so times 1st....connections can get funny here.
gsdtrainer
  • newport,s.wales
« Reply #2 on: 03 May 2010, 20:55:59 »
cheers,jb,tried it a few times but no joy,baffled now :-?
KW
« Reply #3 on: 04 May 2010, 07:02:44 »
It can only be the hazard switch based on what you describe.
A squirt of switch cleaner may help, but a secondhand switch will only be pennies and can be swapped in minutes.
I know violence isn't the answer, I got it wrong on purpose.
    • E250 Est / Elroq
« Reply #4 on: 04 May 2010, 13:04:17 »
hmmm, have you got / had a towbar?  worth checking where the connectors were taken from if so.
gsdtrainer
  • newport,s.wales
« Reply #5 on: 04 May 2010, 21:03:05 »
cheers,kw and jb,will check both options when I get five mins.
