Author Topic: The case for proper assistance - stop lights  (Read 2560 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« on: 15 March 2010, 08:30:16 »
I have posted on here recently regarding intermittent fault with tail warning light - light coming on but bulb working. I had taken at face value when I asked my wife if stop lights working and she has always said yes.
She is away at moment and my 80 year old neighbour tells me my near side stop light is out!!
Changed bulb - problem stops.
I assume it is not possible to have an intermittent stop light fault - i.e. if it goes thats it - no half way house?
You can't get the staff.
    • E250 Est / Elroq
Re: The case for proper assistance - stop lights
« Reply #1 on: 15 March 2010, 08:33:53 »
You can often get a false error with worn out, or cheap 3rd party bulbs.
The measurement is for resistance, not a light sensor, so can be fooled.
New, GM or good make bulbs fix the intermittancy normally.
« Reply #2 on: 15 March 2010, 08:39:15 »
Actually it is possible for a bulb, when nearing the end of it's life normally, to work intermittently... But it's rare to see it on a stop lamp :-/
pscocoa
« Reply #3 on: 15 March 2010, 08:41:02 »
Thanks - fitted a GM bulb - think the old one was GM as well but could have been in there 9 years.
« Reply #4 on: 15 March 2010, 16:01:30 »
Now go and say 'sorry' to your missus ;D ;D ;)
Sixstring
  • Lydney, Gloucestershire
« Reply #5 on: 15 March 2010, 16:05:35 »
Funnily enough, have fitted LED stop/taillights on mine, expected the bulb sensor to throw a wobbly, (hasn't done so) and lights are much more noticeable.
Might be a good alternative?
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
« Reply #6 on: 15 May 2010, 00:23:32 »
I've been looking at these, good to know the car doesn't care!.
Can you recommend a decent set, as there is so much cheap chinese LED out there
Cheers
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
Skint
« Reply #7 on: 15 May 2010, 17:53:47 »
Occasionally it is only corrosion on the bottom of the bulb or the contacts, often got them working by scraping the base of them on a handy piece of tarmac/concrete/paving slab delete as appropriate. If its the contacts it will look different to other contacts or areas of metal not in contact with the bulb. I often use a bit of Vaseline to help protect them.
Sixstring
« Reply #8 on: 17 May 2010, 10:30:48 »
Sorry for the delay, had to find the ripped up packaging in the bin!!
They are "Prism" 360 deg l.e.d. bulbs by "Ring Automotive"
cost me £9.36 for a pair, and while you are at it, the reversing lamp white bulbs from the same people are £6.50 for a pair.
Very good!!
Mike.
Page created in 0.009 seconds with 20 queries.
