Author Topic: Traction Control Mount  (Read 2921 times)
Boditza
  • Craiova, Romania
« on: 24 May 2010, 09:04:38 »
I have an omega 2,2 dti estate 2002, but without traction control.. is there any way i can mount it or activate it from the ecu?? has anyone done this before?? when its snow it slides like a boat uncontrolable.
  • Online Online
Re: Traction Control Mount
« Reply #1 on: 24 May 2010, 09:08:23 »
....... when its snow it slides like a boat uncontrolable.
Just press the right had pedal more gently  :y  :y
« Reply #2 on: 24 May 2010, 09:14:20 »
I do not believe its possible on that car.
    • E250 Est / Elroq
« Reply #3 on: 24 May 2010, 09:15:07 »
No you cant, plus traction control I find, does more harm than good in the snow, I always turn it off, find you get more control, providing you drive gently.
Make better snow preparations, get a lot of weight in the boot to get more traction on the driven wheels, also you can reduce tyre pressure a bit, also helps.
Boditza
  • Craiova, Romania
« Reply #4 on: 24 May 2010, 11:30:55 »
pfff.... i verry much hoped i could... if i find another car like mine that has tc what should i take from that and mount on mine?
« Reply #5 on: 24 May 2010, 11:34:25 »
Engine ECU, ABS ECU (and possibly hydraulics?), Gearbox ECU.  Might need loom, you will need button and bulb for dash.
« Last Edit: 24 May 2010, 11:35:04 by TheBoy »
Boditza
  • Craiova, Romania
« Reply #6 on: 24 May 2010, 13:07:56 »
too much and too much trouble :).. thank you all for the help. i heard that i culd do it just by writing new software on the car ecu and activate tc thats why i asked here to confirm |:)
    • 530D M Sport, 330i Coupe
« Reply #7 on: 24 May 2010, 13:10:15 »
No ABS modulator fitted so no ABS ecu to enable!
« Reply #8 on: 24 May 2010, 13:46:25 »
Correct. The ABS modulator needs another set of valves to implement TC so the capability simply isn't there in "hardware".
You'll probably find the engine ECU is not capable / configured to support TC either, as it wasn't fitted on a 2.2.
