Author Topic: retrofitting variable intermittant wipe.  (Read 5997 times)
    • E250 Est / Elroq
« on: 03 June 2010, 21:28:16 »
My old car has the variable intermittant wipe.
my new one doesnt.
Is it just a case of swapping stalks and relay (which one?)
or is there extra wiring required? (as per the mod to fit to a vectra b)
Cheers
hotel21
  • The Kingdom of Fife
Re: retrofitting variable intermittant wipe.
« Reply #1 on: 03 June 2010, 22:17:23 »
Watching quietly on the side, to see what develops.....   :-X   ;)
Sons 3.0 facelift estate had variable wipe (and rear wash/wipe) but mine does not, for some reason. Dunno why, his had the same spec as mine.... ::)
« Last Edit: 03 June 2010, 22:18:52 by hotel21 »
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #2 on: 03 June 2010, 22:39:39 »
is it because they have auto rain sensors?
PS Completely off topic - why does jimbob have less stars by his name compared to hotel 21 even though he has more posts?
« Last Edit: 03 June 2010, 22:45:06 by radar »
« Reply #3 on: 03 June 2010, 23:03:46 »
my new one doesnt.
Cheers
To get the full range of timed intermittency you need to swap the relay under the bonnet as well.
http://www.omegaowners.com/forum/YaBB.pl?num=1225410105/25#25
« Last Edit: 03 June 2010, 23:05:21 by RobG »
« Reply #4 on: 03 June 2010, 23:05:50 »
Mine too. I think when the rain sensor came out they decided it was that or fixed intermittent. Wouldn't mind making mine variable actually. :y
hotel21
« Reply #5 on: 03 June 2010, 23:05:52 »
Jimbob is a moderator whereby he can and does add to and edit posts but cannot move posts/threads, delete users or update user profiles, unlike an admin.
Hopefully, thats an explanation in a nutshell!     :y
hotel21
« Reply #6 on: 03 June 2010, 23:07:46 »
That would explain it nicely, thanks.....
Whats needed, do you think, to get the rain sensitive bit sorted?
« Reply #7 on: 03 June 2010, 23:07:58 »
Jimbob is a nobody, Hotel21 is also a nobody a god
:P :P
« Reply #8 on: 03 June 2010, 23:08:38 »
I have a saloon stalk from a 2000 Elite. If you can tell me which relay, I have that too ;D
« Reply #9 on: 03 June 2010, 23:17:43 »
Ahh, now, I had that out and played with it, until I realised it was my wiper motor that was fubar. It's one of the relays in the box by the battery. Yellow one in front of the two purple ones (main engine relay and fuel pump relay) I think.
« Reply #10 on: 03 June 2010, 23:25:13 »
That`s the one,  :y
« Last Edit: 03 June 2010, 23:25:39 by RobG »
    • E250 Est / Elroq
« Reply #11 on: 04 June 2010, 07:09:53 »
So anyone know if the loom is there for it to work?
iirc on the vectra B, you added the stalk, the relay, and ran a couple of wires.
As they were standard on so many omega's I am hoping its just the stalk and relay needed. and the plugs are already there.
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #12 on: 04 June 2010, 08:57:21 »
:P :P
LOL! Nice one!!
« Reply #13 on: 04 June 2010, 11:36:43 »
I believe the variable wipe works by placing a resistance in the feed from switch to delay relay instead of just a short circuit, so the wire is there. May need to bodge the connectors at the stalk end if they are different though. Will have a TIS later. :y
« Reply #14 on: 04 June 2010, 11:41:28 »
Read the guide in my reply all info needed is there :y
« Last Edit: 04 June 2010, 12:26:11 by RobG »
Page created in 0.035 seconds with 20 queries.
