Pages: [1] 2 3  All   Go Down
Author Topic: Bose 2006  (Read 8534 times)
Bose 2006
« on: 22 June 2010, 15:27:40 »
Can I replace a faulty Bose CCR 2006 with a CDR 2005 or do you have the same problems with the ohms of the speakers?
TIA :y
Re: Bose 2006
« Reply #1 on: 22 June 2010, 15:32:23 »
If the car has a Bose system then the 2005 will need to be coded for Bose using a Tech 2, if it's possible for that model of Head Unit. :-/
Otherwise, the whole Bose setup needs to be replaced with non-Bose.
Re: Bose 2006
« Reply #2 on: 22 June 2010, 18:43:05 »
cdr2005 does not have a Bose config.
However, it can be fitted with a bose amp, but the volume is fairly uncontrollable at low volume, the tone is slightly off (tweakable with normal bass/treble), distortion at high volume.
I have seen a few like this, due to ccr2006 being a heap of junk (not as bad as cdr2005 though :P), and it can work. HOWEVER, you are running outside of its capabilities, and you are running closer to the point of it tuning into channel smoke....
Re: Bose 2006
« Reply #3 on: 22 June 2010, 23:28:59 »
I guess you could attenuate the signal between head unit and Bose amp to give you normal volume control. :-/ Be a bodge though. ::)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bose 2006
« Reply #4 on: 23 June 2010, 08:17:57 »
Not really, its not just a lower voltage signal thats needed, its a narrower range from low to high.
BOSE equipment only works with BOSE equipment
Radio & Decoding Technician
www.dndservices.co.uk
Re: Bose 2006
« Reply #5 on: 23 June 2010, 09:41:00 »
In what respect? Are you saying they compress the dynamic range of the signal?  :-/
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Bose 2006
« Reply #6 on: 23 June 2010, 10:17:08 »
Think Dave means the Headroom (right levels out to the right levels in, at a given impedance), but having said that, cant see why you cant attenuate the o/p of the HU to a given level and then match the i/p impedance of the amp, assuming you know what they should be.  :-/
« Last Edit: 23 June 2010, 10:29:09 by zirk »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bose 2006
« Reply #7 on: 23 June 2010, 10:41:25 »
OK, without getting too technical, imagine  a volume control with numbers from 0 to 10 on it.
O is the lowest volume and 10 is the max volume.
this is what a "normal" head unit gives out.
A bose head unit using the same control would be say 3 to 7  where 3 is the lowest volume and 7 is the max volume.
A non BOSE head unit if connected to a BOSE amp will give no volume when used from 0 to 3
and between 3 and 7 will give no smooth control over the volume
and from 7 to 10 will probably cause it to go bang as it is now being overdriven.
Sooner or later people will listen
YOU CANNOT MIX BOSE WITH NON BOSE EQUIPMENT
Re: Bose 2006
« Reply #8 on: 23 June 2010, 11:07:23 »
I'm listening. ;) I have no intention of ever owning any Bose equipment let alone mixing it with anything else. I just want to understand what's special about what appears at first glance to be a straightforward audio interface from head unit to amp. ;)
Maybe one day I'll chuck a test CD in my CCR2006, set it to Bose and see what comes out of the speaker outs. ;)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bose 2006
« Reply #9 on: 23 June 2010, 11:26:17 »
There is a Porsche / BOSE interface allowing the use of an aftermarket stereo in a 996, that on the face of it "should" work on the Omega, but I am not aware of anyone who has tried it yet.
zirk
  • Epping Forest
Re: Bose 2006
« Reply #10 on: 23 June 2010, 11:41:02 »
Dave, chill man, your gonna burst a blood vessel, its only 11 o'clock, what you going to be like after England Match this afternoon.   :D
    • E250 Est / Elroq
Re: Bose 2006
« Reply #12 on: 23 June 2010, 11:49:20 »
Do you mean this Dave?
http://cgi.ebay.co.uk/PC9-408-Autoleads-AUDI-A3-4-6-8-PORSCHE-BOSE-ACTIVE-/290384593089?cmd=ViewItem&pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item439c4540c1
looks cheap enough to have a play with  :y
Well, that cant have anything more than a few R's in it.
I suppose that the bose amp could expect a Linearly controlled amplitude feed where as a standard speaker out is Log.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bose 2006
« Reply #13 on: 23 June 2010, 12:47:04 »
Yep, thats along the lines of the thing I was looking at - Although Audi units are generally different levels to Porsche (but only "Anoraks" would tell the difference in quality), this BOSE adaptor may actually work as a good compromise - and certainly worth a try, as could solve a real headache in "Oof Land".
Drunk probably !!  But not watching the footie though, there is a high tide at around 4pm, a bucket full of bait, and the beach is a mere 400 yards away on a blisteringly hot sunny afternoon, and as nobody else appears to be working either, I do have a dilemma . . .
A spot of Fishing?, or being Billy No Mates sat here answering yet another boring question about BOSE compatabilities.
 :P   ;)
zirk
  • Epping Forest
Re: Bose 2006
« Reply #14 on: 23 June 2010, 12:54:14 »
 :P   ;)
Maybe you should write a book on it,.............. about the fishing I mean.
« Last Edit: 23 June 2010, 12:57:15 by zirk »
Pages: [1] 2 3  All   Go Up
