Author Topic: Faulty lambda sensor? ECU codes 38 and 91  (Read 1668 times)
widing
« on: 28 June 2010, 20:18:54 »
I have a 1996 Opel Omega. And got the fault codes:
38 and 91. Is my lambda sensor faulty?
widing
Re: Faulty lambda sensor? ECU codes 38 and 91
« Reply #1 on: 28 June 2010, 20:20:13 »
38 Oxygen sensor circuit - voltage high
91 Oxygen heating - voltage high
« Reply #2 on: 28 June 2010, 20:46:52 »
Before condemning the sensor I`d do a thorough inspection of the wiring first
widing
« Reply #3 on: 28 June 2010, 20:57:37 »
I've check the connector and it loosk fine, what else should i check?
  • Auckland
    • Mazda MPV
« Reply #4 on: 28 June 2010, 22:09:55 »
I think the two 'high voltage' signals indicate an open circuit.
An open circuit could be caused by either faulty wiring or a faulty sensor.
If you have satisfied yourself that it isn't a wiring fault then it is probably time for a new lambda sensor.
Page created in 0.051 seconds with 20 queries.
