Author Topic: elite sound system help  (Read 6138 times)
elite col
« on: 04 July 2010, 12:13:46 »
hi ive bought an aftermarket new sony headunit,ive installed it,all powers up but no sound,and all wires correct on plugs
are the bose speakers ran through an amp that needs to be triggered?
and where is this amp?
any help appreciated
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: elite sound system help
« Reply #1 on: 04 July 2010, 12:17:39 »
AMP should sit in the boot. At the top, in a tray....unless like in my case, some bugger removed it ?
markspark
  • Bolton
« Reply #2 on: 04 July 2010, 12:17:40 »
the amp is under the rear shelf on a saloon not sure on the estate
charlie
  • sunderland
« Reply #3 on: 04 July 2010, 12:18:10 »
 i think you carnt run non bose h/u with bose speaker and vice versa i would take the h/u out and wait for davednd  to answer the post :y :y
    • E250 Est / Elroq
« Reply #4 on: 04 July 2010, 12:20:49 »
if youve still got the bose amp, and bose speakers....with a Sony Headunit.
Wait for the bang and smoke!
    • E250 Est / Elroq
« Reply #5 on: 04 July 2010, 12:21:35 »
[movedhere] Omega General Help [move by] Jimbob.
elite col
« Reply #6 on: 04 July 2010, 12:23:22 »
can someone please explain?
ive never heard of speakers that only work with same make of head unit
elite col
« Reply #7 on: 04 July 2010, 12:29:45 »
bang and smoke?
from what the amp?
as positive and negative all ok
    • 530D M Sport, 330i Coupe
« Reply #8 on: 04 July 2010, 12:34:02 »
Bose amp and speakers run a 2Ohm impedence. Bose tweaked (via Tech II) head units have suitably lowered outputs to match the Bose amps input requirements.
elite col
« Reply #9 on: 04 July 2010, 12:36:17 »
so cant i do away with amp and run speakers from new headunit outputs?
« Reply #10 on: 04 July 2010, 12:37:19 »
Need to change the speakers to 4 ohm as well....  :'(
« Reply #11 on: 04 July 2010, 12:39:22 »
bang and smoke?
from what the amp?
No your head unit! Bose speakers are 2Ohm, all other 'standard' retail speakers are 4Ohm, these need to be replaced, or it will blow up your H/U.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #12 on: 04 July 2010, 12:50:43 »
The problem is the Sony HU gives standard RCA line levels out where the Bose Amp is expecting a wierd (Bose HU speaker level out) input, add as well, that the Sony RCA is an Unbalanced o/p and the Bose Amp is Balanced i/p then all the levels and impedences are up the wall.
Edit, unless you have wired the Sony to drive the speakers (or thinking you have) then the Bose Amps in the way, again wrong levels and impedences.
« Last Edit: 04 July 2010, 12:54:26 by zirk »
« Reply #13 on: 04 July 2010, 15:11:49 »
Have a read through this section, there's loads of info about it.
elite col
« Reply #14 on: 04 July 2010, 15:54:50 »
i really wish id looked into this 1st
but i had never heard of anything like this on any car
i like the sound off the bose speakers aswell,no way id be able to afford to buy bose ones for replacements
should of stuck with fords lol
Page created in 0.026 seconds with 20 queries.
