Author Topic: facelift radio removal  (Read 1773 times)
tidla
  • solihull
« on: 20 July 2010, 22:09:37 »
must be the hot weather.
my unit in particlular is the ncdc2013 .
seen quite a few threads requesting help with the removal of the double din units.
http://www.omegaowners.com/forum/YaBB.pl?num=1279322269/0
on seeing some helpful pics on a similar thread and suffering  the dilemma as not being able to remove my radio, i thought on doing the job i would take some piccys which might be of help to others.
first problem is the crappy keys.
tried the local vauxhall agent who was adamant that the keys were not available on their own and only came with a new radio??
halfords supplied brand it is then.
the keys probably do the job of moving the spring retainers away from the securing cage. the only drawback is, as there is no where to stick your fingers "in" the unit , you are dependant on the keys to draw the unit forward.
the keys should latch onto a small lug, and enable you to draw the unit forward using the pull on the keys only.
the trouble is that the key profile is too poor to do this so a little mod is in order.
one side of the key on both ends can be filed slightly so a to create a nice sharp 90. edge to catch the lug.
on insertion of the key this has to enter "radio side"
next is a piccy of how the pins should engage to remove the unit.
that i feel should be enough to remove the unit, if not, read on...
if you still need further leverage to remove the unit (the securing clips hold the unit in place but other resistance to over come is the fixed power, speaker and ariel plugs)
 then rather that grip by the ash tray edge which as it happens is the most likley place to rip off the front of the radio, remove the side switches which will give you access to the side of the radio.
this will give you plenty of space and additional load bearing surface for careful leverage one side at a time until the radio untill its free.
spring edged switches are easily removed using a thin flat blade screwdriver.(the fronts of the swiches can come off so care is reqd)
radio and switches removed.(half a hazard switch)
hope the additional info is of help giving confidence that you wont totally wreck a repairable unit on removal!
the permanently expanded cd cartridge which prevented me getting my loaned rick astley cd s out :y
any futher comments and amendments welcome.
« Last Edit: 20 July 2010, 22:14:18 by tapper888 »
Re: facelift radio removal
« Reply #1 on: 20 July 2010, 22:13:36 »
The key mod, if done right, is usually always enough :y, if not, you have to fabricate some better keys.  The Autoleads ones, as sold by Halfords, are particularly crap.
If the front gets ripped off, that will always come to give you reliability issues later, so do NOT be tempted to pull on the facia to remove.
    • E250 Est / Elroq
« Reply #2 on: 21 July 2010, 07:54:37 »
Handy guide, if you would put the same thing in the test section, I will then move it to the Maint guides section  :y
Been searching EPC for the keys, but cannot see them, Ill see if I can find a part number.
Interestingly I have found a Vauxhall Double Din to Single Din converter.
Wonder how much that is, and what the colour match is  :-/ (93160594)
Chimpchoker
  • Hartlepool
  • 1
    • A beautiful omega 2.6 V6
    • Bselfsufficient
« Reply #3 on: 23 July 2010, 11:11:17 »
There is one here but as usual no conection with company or used their products
http://www.dynamicsounds.co.uk/autoleads-dfp1900cg-vauxhall-meriva-omega-charcoal-grey-double-fascia-p-15324.html
and another one here.
http://www.auto-connect.co.uk/VAUXHALL.html
Hope that helps. I know I need some speaker adapters for the 16 cm speakers i have ready to fit in... so much to do so little money....
« Last Edit: 23 July 2010, 11:19:39 by Chimpchoker »
windup merchant of the first order
