Passenger door puddle light not working
Started by ScaniaV8, 09 August 2010, 09:23:36
ScaniaV8
All other 3 doors work ok when opening, checked the passenger door puddle light bulb and it had blown so I replaced with new bulb but still not working. Main interior lights do come on Ok when passenger door is opened but not the puddle light !
Any clues to what could be the problem?
Also no sound to my passenger door speaker! (I have checked the balance control and fader controls and these seem to be working ok fine but no sound to the passenger front door speaker. Is my puddle light and speaker problem likely to be related? :(
cheers
Brikhead
I'd guess the problems are related, start by checking the wiring loom where it passes from the car body into the door. Open the door and look inbetween the hinges for the rubber umbilical which carries the wiring loom. Peel back the rubber and check for chaffed wires.
I_want_an_Omega
The switch is a double contact one. One for the door light, the other for the alarm/main interior light etc.
If you gently remove the switch and carefully look at the wires to it you may find a bad connection - but be careful not to let go as if the wites go back inside the door hole you are stuffed.
Brikhead
QuoteThe switch is a double contact one. One for the door light, the other for the alarm/main interior light etc.
Will that fix the speaker problem too?
I_want_an_Omega
The systems are totally separate - but the wires will run together in a single bunch - so if physical damange has occured it may well have impacted more than one wire.
