Pages: [1] 2 3  All   Go Down
Author Topic: Variable intermittent wiper - an easier way?  (Read 8964 times)
« on: 07 August 2010, 13:19:37 »
OK. I did it the obvious way on my Omega and it works nicely.
Here's the guide to recap:
http://www.omegaowners.com/forum/YaBB.pl?num=1279100997
One of the things I want to add to the Westfield is an intermittent wipe - it doesn't have one at all, let alone variable!
Anyway, I've been rersearching ways to do this and came across a VW part which implements variable intermittent wipe in quite a neat way.
This wiper delay timer "learns" the wiper interval in the following way:
It starts drizzling, so you flick the wipers once. It keeps drizzling so, when the screen is in need of another wipe, you flick it onto intermittent. The wiper delay timer sets itself to the time interval between your initial "flick" of the wipers and when you switched it to intermittent, and carries on using that interval thereafter.
So.. No need for a stalk with a variable setting and, the best part, this relay is pin compatible with the non-variable timer module already fitted in Omegas without variable intermittent!
The upgrade simply involves lifting the bonnet, pulling out the old timer module and plugging in the new one.
I should stress that I haven't tried this in an Omega as I've already changed the stalk on mine however I have obtained a timer module, tested it on the bench and I can't see any reason why this wouldn't work on an Omega. It behaves exactly as my old non-variable timer module except that you can set the time interval. 8-)
If anyone wants to try this, you will need the timer module which is VW part number 357 955 531. Also referred to on the net as the "99" relay as it often has a large number 99 printed on the case. This site suggests that there are some equivalent parts but I can't vouch for its' accuracy.http://wiki.seloc.org/a/Wiper_Variable_intermittent
I ordered one from ebay seller stevens_vw_dismantlers mid-afternoon yesterday and it was on the mat waiting this morning when i got up (OK, I had a lie-in). :y
I stress that I haven't tried this on an Omega but if someone would like to volunteer to try it out I will agree to buy back their relay if it doesn't work, such is my confidence that it will. Once it has been verified I will add the info to the guide.
Re: Variable intermittent wiper - an easier way?
« Reply #1 on: 07 August 2010, 15:33:14 »
There are various Senators & Carltons out there with this handy mod  :y  :y  :y  :y
« Reply #2 on: 07 August 2010, 16:02:36 »
Yes, googling for info reveals it seems to be popular on quite a few models of car. Quite surprising it hasn't reached the Omega community before.
« Reply #3 on: 07 August 2010, 16:04:10 »
...... Quite surprising it hasn't reached the Omega community before.
Presumabaly cos there's a variable intermittant wiper switch already available for an Omega.  ;)  ;)
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #4 on: 07 August 2010, 16:07:19 »
Though this a while back.
Newer VXs of lesser ilk have the variable timer method intemittant wipe relay.
My question at the time was - are these pin-for pin compatible with the Omegas ??   I was going to get one to try but, alas didn't get a "round tuit" in time - so didn't ever find out.  But now you've rekindled my interest ...
    • E250 Est / Elroq
« Reply #5 on: 09 August 2010, 17:01:53 »
I like the sound of that.
wonder if it will work on the estate  :-/
« Reply #6 on: 09 August 2010, 18:09:46 »
I don't see why not, Jimbob. Only difference on the estate is there's some more gubbins on the stalk for the rear wiper. Front wiper circuit looks identical. :y
    • E250 Est / Elroq
« Reply #7 on: 09 August 2010, 20:08:01 »
Why not bring it to Newent....lets have a play  :y
« Reply #8 on: 09 August 2010, 22:07:27 »
Yep, will do. Hopefully fitted to a Westfield.
Big_Roger
  • Southampton
« Reply #9 on: 17 August 2010, 16:09:44 »
Hi All,
Yup, this is an easy way to fit variable delay wipers if not OEM on your version of the Omega.
Mine is the ex plod 02 3.2 Estate only fitted with fixed delay wipers.
I sent for the relay from same place as Kevin £12.49 (VW dealer in Southampton wanted £38.00) Looked up on maintenance guide on here for location of relay, on mine relay K8, position 9 (tall yellow relay) in relay box.
Swapped relays, and hey presto now have programmable wiper delay.
Well done Kevin.
Regards
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
    • E250 Est / Elroq
« Reply #10 on: 17 August 2010, 16:34:16 »
youve reignited my interest, so gone for one  :y
« Reply #11 on: 17 August 2010, 17:12:15 »
Sounds good .. think I'll try it as well ... especialy with Kevin's "money back" guarantee ....  :)
« Last Edit: 17 August 2010, 17:19:12 by entwood »
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #12 on: 17 August 2010, 17:24:38 »
Think I will have a go at this for my ex-plod :y
« Reply #13 on: 17 August 2010, 17:25:58 »
I'll continue to use the 'flick wipe' feature in my Astra shed .......  ;)  ;)  ;)  :y
« Reply #14 on: 18 August 2010, 10:06:13 »
Doesn't yours have a rain sensor?
.. and as for the money back guarantee, the solution has been proven by Big_Roger so any problems will be considered down to user error and not covered. :P
Pages: [1] 2 3  All   Go Up
