Pages: 1 [2] 3  All   Go Down
Author Topic: Variable intermittent wiper - an easier way?  (Read 8967 times)
Re: Variable intermittent wiper - an easier way?
« Reply #15 on: 18 August 2010, 13:08:56 »
Sounds good .. think I'll try it as well ... especialy with Kevin's "money back" guarantee ....  :)
Doesn't yours have a rain sensor?
.. and as for the money back guarantee, the solution has been proven by Big_Roger so any problems will be considered down to user error and not covered. :P
No rain sensors on this one, and fixed intermittent which is why I'm trying your idea ...  :)
And as to the withdrawal of the guarantee on such slim grounds ... well I'm lost for words .....
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Last Edit: 18 August 2010, 13:09:17 by entwood »
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #16 on: 18 August 2010, 20:37:22 »
OK I've sent for one, same place should be here in the morning. Thing is can't get the old relay out, does it just pull out or am I missing something  :-?
« Reply #17 on: 18 August 2010, 22:16:11 »
It does just pull out but sometimes they can be stiff. Might help to remove the whole socket and ease it out with a flat bladed screwdriver.
« Reply #18 on: 18 August 2010, 22:34:07 »
Thanks for the Heads Up Kevin, mine's on order  :y
hotel21
  • The Kingdom of Fife
« Reply #19 on: 18 August 2010, 22:41:37 »
Got the flick then intermittant which sets the delay interval thing.  How do you reset it to another timing?  Switch off and restart/repeat as required??   :-/
« Reply #20 on: 18 August 2010, 23:58:38 »
Yes, I think so.
I have added the above details to the maintenance guide.
« Reply #21 on: 19 August 2010, 00:46:26 »
Got rain sensor me.  :P.  A more "Elite" Elite  8-)
« Reply #22 on: 19 August 2010, 14:22:30 »
Right . ... relay arrived and installed .. just got to learn how to use it now !!!
So ... "flick wipe" by single pull up on stalk as if about to wash screen. Then select intermittant and the relay will "learn" that time interval ??
or am I a numpty ??   :)
    • E250 Est / Elroq
« Reply #23 on: 19 August 2010, 14:27:39 »
That is my understanding, but not done it yet, and the time between the flick, and selecting intermittant becomes the time interval until next time.
hotel21
« Reply #24 on: 19 August 2010, 18:24:30 »
Think its more of the vertical, normal axis of movement, quick single wipe type activation rather than back towards you wash/wipe.  Then click onto intermittant and the relay does the time repeat interval between the two activations until switched off/further on.  ;)
« Reply #25 on: 19 August 2010, 19:24:17 »
Ahh I get you ... so towards intermittent but not quite for the "flick wipe" then into intermittent to set the time gap .. :)
Will try tomorrow as it looks certain to be raining !!!  :(
    • E250 Est / Elroq
« Reply #26 on: 20 August 2010, 16:49:46 »
Just fitted mine, and seems to work fine  :y
found a 3 pin connector not connected to anything in the fuse box....normal?  not been in a 3.2 box before, isnt the ecu tiny  ;D
edit : the above query now here http://www.omegaowners.com/forum/YaBB.pl?num=1282320035/0#0
« Last Edit: 20 August 2010, 17:01:13 by jimbob »
« Reply #27 on: 20 August 2010, 17:39:44 »
Corsas had this....
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #28 on: 20 August 2010, 20:35:33 »
Fitted mine yesterday and today came the rain and it works fine, thank you all. :y
« Reply #29 on: 20 August 2010, 20:52:08 »
Fitted mine today too & works AOK! Many Thanks to Kevin Wood for the 'Heads Up' :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.088 seconds with 20 queries.
