central locking
Started by DOCTORWHO, 30 September 2010, 21:32:20
DOCTORWHO
evening al
This is my first bit of help needed,,thanks
my drivers door solenoid doesnt work,,does anyone know the part number,otherwise i have to strip door panel,,,get replacement etc,,,if i have solenoid ready,it would be a lot easier
Thanks again
Colin
sorry,,its an 02 reg
Quoteevening al
Thanks again
Colin
Have a look here, this guy is called Steve, he is a member here. Mention you are from the OOF & you will get a discount? Even if you don't buy from him, all the details you need are there  :y
http://cgi.ebay.co.uk/OPEL-OMEGA-FRONT-DOOR-LOCK-SOLENOID-90-493-702-90493702-/310249086981?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483c496005
Central locking motors can be repaired if you are Ok with a soldering iron. :y
http://www.omegaowners.com/forum/YaBB.pl?num=1275155915
Carfix
Yep, I have repaired two by replacing the micro switch using the "how to" guide.
Parts are readily available from RS components (and possibly Maplins).
Been a year since repair and both solenoids are working fine.
doug4293
the central locking isnt working in mine, how can i tell whats causing it to fail, doesnt work from key, doesnt work from lock in car doors and doesnt work form the open/close alarm fob buttons .
Signature deleted as it's too big.
