Omega Engine Managment light Staying on
Started by Tornado632, 14 October 2010, 18:26:19
Tornado632
Hi Guys
Just changed my exhaust down pipe on my 1999 20l 16v ecotec Automatic, started the car and it ran rough for a bit but now its ok, but the engine managment light is staying on... Can I bring up the flash codes by using the paper clip trick or is my car too new! I seem to have two diagnostic plugs, one in the main fuse box and one next to the servo unit, can anyone tell me which is the correct one.
Yes, and its one under steering wheel.
The one on suspension turrent isn't a diag connector, its the cruise control loom.
Welung666
As TB says you can paperclip it, instructions are below :y
Tornado632
Hi
Thanks for the info, but no Instructions came through...
Cheers
have you checked that you've not disturbed any connectors possibly the lambda sensor as you've been working nearby  :-/
Tornado632
Hi
Yes I have, when I first started the car after fitting the exhaust is was runing badly, but now its runing ok so I think the fault is gone but still stored in the ECU and only need to be cleared to put the light out..
Simon72
QuoteHi
Cheers
His instructions for the paperclip test were in his SIGNATURE ;-)
Heres the link :- http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Welung666
QuoteHi
Cheers
Eyes wide shut! ;) :P ;D ;D
