Author Topic: Keyfob Lock button locks then unlocks doors  (Read 1896 times)
Welsh Dan
« on: 26 October 2010, 19:26:57 »
Righto, one of the other problems i've found. I've just tried locking the car using the three button keyfob. It locked the doors, before unlocking them immediately. The car does have a flat battery, mainly as its been sat up for a few weeks/months without being used, so is this an issue that is related to a flat battery?
Secondly, anywhere to get an additional key from, other than the main stealers? I'd also need the keycode card, which I presume is dealer only?
Re: Keyfob Lock button locks then unlocks doors
« Reply #1 on: 26 October 2010, 19:31:46 »
Righto, one of the other problems i've found. I've just tried locking the car using the three button keyfob. It locked the doors, before unlocking them immediately. The car does have a flat battery, mainly as its been sat up for a few weeks/months without being use d, so is this an issue that is related to a flat battery?   .....
try lubricating the lock mechanism & linkage rods inside the door first. Other than that, you might need a 'new' driver's door locking motor/solenoid.  :y
Depends where you live as to whether anyone local has a Tech II to programme fobs - new or second hand. Key cutters near me were reluctant to cut Omega type keys when I asked. Dealer only as you say for Car Pass.
« Last Edit: 26 October 2010, 19:37:51 by Andy_B »
« Reply #2 on: 26 October 2010, 19:55:34 »
I'm guessing you're not far from me, going by PMs?
Keys from egay, fob from dealer, tech2 from me.  Carpass from dealer, but shop around, as price varies from £15 to £50
Welsh Dan
« Reply #3 on: 26 October 2010, 22:18:49 »
I'm in Enfield, so you appeared to be the closest :)
I've sorted the lock issue now and it appeared to be related to a flat battery. Battery has been charged and the car taken on a good run, which has brought up one or two other issues.
« Reply #4 on: 27 October 2010, 18:22:26 »
Assuming you can get another key in time, there is always the oxford meet this saturday :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #5 on: 30 October 2010, 20:06:49 »
Yep, flat battery. Had that once before, myself. Nice if i had remembered that before you found that out yourself! I'll try to be a bit quicker next time!  :y :y
