Author Topic: Power Sounder going off . . . . quietly ????  (Read 2312 times)
FatS
  • nr Chelmsford - ESSEX !
  • sorry about the last avatar :-(
« on: 05 December 2010, 11:46:45 »
http://www.omegaowners.com/forum/YaBB.pl?num=1220198611
Does this isolate the Power Sounder from the main battery ???
My battery is going flat over 1-2 days ????
Just noticed a little squeeking/alarm noise
just behind the clocks and i can't stop it
by locking/unlocking doors with key OR fob
PLEASE ! ! ! ! ! !  :-[ :-[
[ used to have 2.5 MANUAL before . . THAT'S why i've gone for the AUTO :-) ]
Re: Power Sounder going off . . . . quietly ????
« Reply #1 on: 05 December 2010, 11:49:48 »
Yep :y
    • E250 Est / Elroq
« Reply #2 on: 05 December 2010, 12:10:31 »
ours did that....just before it went on fire!
FatS
« Reply #3 on: 05 December 2010, 12:14:19 »
Hi guys
thanks for the info .... Fats is outside now trying to get the wiper arm off!!!!!
Cheers
Fats "better" half  ;)
« Reply #4 on: 05 December 2010, 12:31:45 »
Hi guys
Cheers
Un-do the nut, its a 10mm i think - Fold the wiper arm out, then wiggle the hell out of it  ;D
FatS
« Reply #5 on: 05 December 2010, 12:54:35 »
http://www.flickr.com/photos/23392067@N04/5234416030/
http://www.flickr.com/photos/23392067@N04/5234415948/
http://www.flickr.com/photos/23392067@N04/5233823251/
IS this the plug ??????
CAN'T get the blee*in wiper arm off  :-X
BUT pulling the plastic up could see the Battery ??
and this plug is in SIDE of the "battery" and can pull off !!
IF it is i can just tape it up ?!?!?!?!?!?
FatS
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #6 on: 05 December 2010, 16:25:53 »
to get wiper off i found that taking the nut off,push down slightly on on the wiper arm spring then tap the wiper arm with the handle of a heavy insulated screwdriver  ;) :y
FatS
« Reply #7 on: 05 December 2010, 17:53:20 »
FatS
well, that's what i've done . . . so, hope it's right ??????
« Reply #8 on: 05 December 2010, 18:22:16 »
Hi guys
Cheers
13mm, and repeatedly press on the hinge part of wiper ;)
« Reply #9 on: 05 December 2010, 18:24:50 »
FatS
Battery? I think you mean the power sounder itself? 10mill nut holding it to a bracket? With that plug attached? No certain that's the right plug from memory but it looks about right.
