park sensor swichboard
Started by miguelito, 15 December 2010, 10:16:52
miguelito
hi, does anybody knows where is located the main swicht of the park sensors in a caravan 2003. please i need also the numer of the GM part. My sensors doon´t work at all and mecachical told me is because of main swicht.
Thanks a lot.
no main switch. The unit is activated by the reverse light wire
miguelito
the sensors need a main swicth to run, theye are activated by reverse light but controlated by the main, if the main doesnt work well they dont detect nothing.
all park sensor are controlated by specifically main swich, but i dont know where is it....
thanks  a lot
this is my third omega, first 2.5td, second 2.5dti berlina and finally a caravan plenty of extras...
Quotethe sensors need a main swicth to run, theye are activated by reverse light but controlated by the main, if the main doesnt work well they dont detect nothing.
thanks  a lot
the control unit is wired directly, not via a switch, then as said is activated/controlled by the reverse lights. there is NO separate switch.  ;)
miguelito
where is this control unit? which could be the problem?Weeks ago the beep became lower and finaly there is no beep... and dont know what the matter.
Thank you again ;)
I_want_an_Omega
I think all he is asking is where is the parking sensor control unit located.
I have no experience of this on the Omega, but on Fords it's located in the rear 1/4 of the load area.
You can always follow the wires back from the sensors - that's a 100% certain way to find it.
Entwood is the man for this, but he's selfishly enjoying himeself in Austrailia  ;D, or Chris, but I think it located above the spare wheel well.  :-/
Quotewhere is this control unit? which could be the problem?Weeks ago the beep became lower and finaly there is no beep... and dont know what the matter.
Thank you again ;)
speaker failed on another elite i have here. I suppose the tell tale would be if the sensors tick audibly or to a light touch, but no tone is heard in the car then good chance the speaker has failed. But i diagnosed mine with an electricians meter which will show a varieing current at the speaker plug with reverse gear selected and ignition on. Engine does not need to be running.
Control unit, remove spare wheel for access, its on the outboard side of the vertical metal panel in the space between panel and rear wing, 2 screws are easy to get to.
Speaker wire has a black braided fabric cover, with a plug covered in foam wrap cable tied to the same metal panel, if faulty unplug it there then from the rear seat remove the c pillar cover on the spare wheel side of the car, you'll see the braided wire running up to the roof lining, unclip the roof lining enough to pull the speaker out, its just stuck to the roof in a lump of foam, exact location seems to varie, but just follow the wire.
If you need to remove it from the car to solder on another speaker then wire will pull through the rear seat bulk head, it will stick but a firm tug and the plug will pull through.
I dont think re fitting is possible in the same route, so i fed the cable back through a hole in the seat bulk head by the seat belt track, then feed the cable to the unit that way instead.
hth
miguelito
thank you  chrisgixer, you gaved me the quiz. ther is a trick to know if the sensors run well, with engine off and reverse gear on put your finger on the sensor, if they are ok you can feel a lower movement, a vibrate in each sensor. this is my case, the problem thats on the speaker. with the help of  chrisgixer i could find the "speaker", is so closed to the rear handle drivers side. ther is a kind of rope recovering the wires. I used a speaker of a house telefone put on the ear side. now all is ok and park sensors run again.
than you a lot from Madrid. (i´ve just forgot most of my english i´ve learned in school.)
Quote.....
It's good enough for us here!  :y  :y
