Car alarms ???
Started by tomoco, 31 December 2010, 13:27:27
tomoco
I want to fit a better sounding alarm to my Omega.
Can i fit a second alarm to the car without it being confused by the O. E. one already fitted.
The powersounder died on me a few years ago which left the pathetic sounding flat circular type, now that has decided to stay on all the time so i've took that off too.
I dont really want to put a replacement horn on . Is it possible to fit a louder siren type to the existing wires or can i just get another alarm and wire that in?
Evering thing else on the alarm is fine, ultrasonics, imobiliser, bonnet, door and boot switches. Even the indicators flash, its just the horn itself.
Any advice would be great thanks
Mark :y
freecall666
QuoteI want to fit a better sounding alarm to my Omega.
Mark :y
if it to loud can get a fine, but there are lots of replacments you can use. just need the alarm code to fit them in from what was told...
Solar charger fitted.
If not Broke dont fix it..
zirk
The horn just operates from a 12v relay, so guessing you replace it with a 12v siren, it will still sound intermittent though.
tomoco
Can i change or alter the relay to make it a continous 12volt supply instead of an intermitent one ?
freecall666
yes its in the back of the glove box, take out the glove box its top left inside, and alarm box is there to. cannot remember the colour of it think its orange or pink, if you set alarm off it will tell you.
tomoco
thanks freecall ,at least i can make a start. Once the supply is sorted there are loads of "LOUD" sirens about he he ;D
Quoteyes its in the back of the glove box, take out the glove box its top left inside, and alarm box is there to. cannot remember the colour of it think its orange or pink, if you set alarm off it will tell you.
Not on a 2.6 though. ;) Alarm ECU is integrated with the central locking and in the driver's side kick panel IIRC.
I would get a new power sounder (about £50 from stealers IIRC) and check the siren horn is OK first, as these often fail. With both sounders working they are reasonably loud, IMHO.
I think you would struggle to fit another alarm to operate in conjunction with the factory one. The ultrasonic sensors might well interfere with each other for a start. A siren could be powered from the horn output of the alarm, and no doubt you could prevent it pulsing using some sort of timer. Better off leaving it standard but making sure it's up to scratch, though, IMHO.
tomoco
Thanks Kevin, i was thinking the same thing to be honest . Can you tell if a new sounder will need to be tech II'd or is it plug and play?
Mark
tomoco
Thanks Mark, may need your services soon about a different problem.
Tomo :y
