Author Topic: Remote door lock unlocks then locks again  (Read 2832 times)
robinwhale
  • Redruth, Cornwall, UK
    • Omega Est. 2.2L 2001
    • Sandokai Karate UK
« on: 18 January 2011, 17:48:15 »
Omega Estate; 2.2 manual; 51 Registration/2001; Z16XE engine.
I have a recent problem emerge with my central locking. I can press the button on the key fob and the doors will lock (indicators flash etc) with no problem, but when I try to unlock the door with the key fob the lock unlocks (lights flash, button pops up) and then immediately locks itself again. >:(
I have to use the key in the lock to unlock the door, but on a couple of occasions I have got in the car and the doors have locked by themselves when I shut the door.
I make a point of not leaving the keys in the car unattended in case I lock myself out, but it is an irritating problem.
I'm guessing that this is an electrical fault, maybe something damp with all the rain we've had lately? Any hints or suggestions welcome.
Cheers
Robin
Re: Remote door lock unlocks then locks again
« Reply #1 on: 18 January 2011, 18:04:57 »
.... Any hints or suggestions welcome.
Cheers
Robin
I would start by removing the door card and liberally coating all linkages around the central locking motor & all connecting rods with something like chain lub, ie something penetrating enough to get into the nooks 7 crannies but also sticky enough to not get washed away.
Next step is a 'new' locking motor. they're easy enough to change.  :y :y
Welung666
« Reply #2 on: 18 January 2011, 18:28:48 »
I'd also contact Vauxhall and ask for a proper engine ;D ;D
« Reply #3 on: 18 January 2011, 18:31:52 »
and he could always ask for another 500cc for you  ::)  ::)  ::)
robinwhale
« Reply #4 on: 18 January 2011, 18:40:01 »
I have no problems with the engine. It runs smooth, starts first time every time and gets me where I want to go. What more could I want?
« Reply #5 on: 18 January 2011, 18:43:29 »
...... What more could I want?
Another 2 cylinders!   ;)  ;)  ;D  ;D  :y
Boditza
  • Craiova, Romania
« Reply #6 on: 18 January 2011, 19:26:14 »
Cheers
Robin
well you could check again what is wrong with it.... besides from the missing 2 cyl :))
p.s. the engine is Y22XE not Z16XE :)
robinwhale
« Reply #7 on: 18 January 2011, 20:08:36 »
You are probably right, but the Vauxhall Car Pass in my manual/wallet thingy says Z16XE. Maybe I ought to check the rest of the info like the VIN number ...
Maybe that's why I seem to be 2 cylinders short!
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 19 January 2011, 00:00:03 »
Also worth checking that the actual drivers door knob button is not rubbing / stiff / slightly bent, can create the same issues.
Boditza
  • Craiova, Romania
« Reply #9 on: 19 January 2011, 06:49:26 »
but thats not from your car... the lowest cmc in an omega is the 2,0l gas and diesel... the z16xe is a 1,6l engine(astra, vectra, zafira etc)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #10 on: 21 January 2011, 13:54:31 »
lets hope its not a disguised astra then  :'( :'( ;D
« Reply #11 on: 21 January 2011, 17:01:48 »
Spot on. :y
If the driver's door lock is jammed or the locking motor has failed (common) the driver's door doesn't unlock with the rest. Once the rest of the car is unlocked, the central locking senses that the driver's door is locked and assumes you've locked it manually, so it locks the others using central locking.
Just need to replace / repair the driver's door central locking motor, I reckon.
Page created in 0.031 seconds with 16 queries.
