Author Topic: so whats this all worth  (Read 3923 times)
markspark
  • Bolton
« on: 05 February 2011, 17:39:55 »
Hi guys i have a ncdc 2015 fully working with the cid and the telematics unit just wondering what its worth if i was to sell its still in my car in use at the moment
TIA  :y
Re: so whats this all worth
« Reply #1 on: 05 February 2011, 17:48:28 »
Do you have the facility to depair?
  • Auckland
    • Mazda MPV
« Reply #2 on: 05 February 2011, 17:52:56 »
Do they need to be depaired if the CID and NCDC are going to be  kept together?
« Last Edit: 05 February 2011, 17:53:22 by andyh »
markspark
  • Bolton
« Reply #3 on: 05 February 2011, 18:03:07 »
Depair ?????
  • Auckland
    • Mazda MPV
« Reply #4 on: 05 February 2011, 18:20:22 »
Depair ?????
The NCDC head unit and the CID communicate with each other using CANbus (fancy modern wiring that new cars are full of nowadays).
Each component on the CANbus has to have the same security code as all the others or else it won't work. Replacement components are shipped without a security code. When the replacement is installed it is 'paired' with the other components using the code.
Putting a component in shipping mode (depairing) is damn near impossible once it is taken out of a working set up.
The thing about the Omega is that the CANbus isn't connected to the engine ECU like it is in modern cars so the NCDC doesn't need to be paired with the ECU
markspark
  • Bolton
« Reply #5 on: 05 February 2011, 18:25:21 »
so in essance its all worthless if i remove it?? I do have "My Naff Code Reader" can it be done with this ???
  • Auckland
    • Mazda MPV
« Reply #6 on: 05 February 2011, 18:50:02 »
AFAIK the only reason CANbus was ever installed in an Omega was to connect NCDC head units to the CID (I have this nagging feeling that there might be a third component in some NCDC installs. Boot changer? telematics/phone? perhaps).
If you keep all the components together then they should work in a new install. If you want to separate them you need to go to someone with Tech2 who knows how to use it and have them depaired.
From what I have read on this forum the only person who has tried all the options with Tech2 and NCDC head units is The Boy. (and that includes breaking them).
I know he has had to recover FUBAR key security after failed "My Naff Code Reader" sessions (by others), I don't know if that extends to FUBAR NCDC security  :-/
HTH
« Last Edit: 05 February 2011, 18:53:30 by andyh »
    • E250 Est / Elroq
« Reply #7 on: 06 February 2011, 09:04:41 »
Im sure someone went to TheBoy with an NCDX setup after playing with "My Naff Code Reader"......and I beleive it was then a doorstop, ie unrecoverable  :'(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #8 on: 06 February 2011, 10:01:12 »
I know for certain that I cannot recover the code status from an NCDCxxxx head unit - if not depaired correctly from the original vehicle, then we would simply write them off - no value whatsoever.
Radio & Decoding Technician
www.dndservices.co.uk
markspark
  • Bolton
« Reply #9 on: 06 February 2011, 12:16:57 »
so im right in thinking that depairing can be done with the tech 2 in the correct way how much would this cost ???
Also what are the items worth once this has been done
To put you in the picture im thinking of breaking my 3.2 elite in a few months when the tax runs out im hoping its worth more as parts compaired to the full car value  :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #10 on: 06 February 2011, 12:49:25 »
Is it rusty?
markspark
  • Bolton
« Reply #11 on: 06 February 2011, 13:42:27 »
no not rusty needs some paint due to some idiot scrtching it all down one side
davethediver
  • Blackburn, Lancs.
« Reply #12 on: 06 February 2011, 13:59:55 »
What's up with the car, what age?
P.A. Caron de Beaumarchais
markspark
  • Bolton
« Reply #13 on: 06 February 2011, 14:24:00 »
TBH there is noting wrong with the car its a 51plate 3.2 Elite with full Irmscher kit in black i just think with the way fuel is going people what be giving good money for them and it would be worth more as parts
« Reply #14 on: 06 February 2011, 15:03:09 »
TBH Mark, you're probably right... The Irmscher kit alone (if in A1 condition) will make a fair bit :y
As for the radio unit... There's a fair chance that someone here will have the complete kit :y
