Outside temp
Started by tango, 09 December 2010, 16:42:48
tango
Hi
My car is not showing the temp outside
It's got F showing on the display
I thought it must be the sensor on the front bumper so I changed that but still the same
Any ideas what it can be
Check & trace wiring back to big black connector under N/S of bumper
tango
Checked the connector
It's a 4 pin plug the one that connects to the fogs too
Seems to be fine
Any other suggestions
mrjimbo
Try unpluging the 4 pin connector a few times and give it a squirt of contact cleaner or WD40, may be a little damp/corrosion got in there. Try the same with the temp sensor as well.
There's a lot of salt out there at the moment and it gets everywhere, salt attracts the damp as well   :y
tango
tried wd40 disconecting and then reconecting but still no joy
any other suggestions please
plym ian
sell the car to me or stick your head out of the window to feel how cold it is ;D ;D ;D ;D
Dave DND
Quotesell the car to me or stick your head out of the window to feel how cold it is ;D ;D ;D ;D
No need to do that . . .
The car is already telling you its "F"-ing cold !!
;D
Radio & Decoding Technician
www.dndservices.co.uk
plym ian
;D
and the ice on the windows/ snow on the ground might tell you to ;D
fiend61
sure that it is a working temp sensor you changed it with  :P
Welung666
If the sensor is OK (very hard to test it) the it's either a broken wire or damp/corrosion in the 4 pin bumper loom plug. I've got a couple of temp sensors here if you want to try a 3rd :y
QuoteHi
It's got F showing on the displayI thought it must be the sensor on the front bumper so I changed that but still the same
As long as it's not showing FFS it can't be too bad! ;D ;)
kcl
Mine is showing inaccurate readings, several degrees out... Any ideas?
Boditza
the sensor.. change it and you will get as acurate readings as it can get :)
kcl
Changed the sensor to a new one and still giving the F. My plug is only 2-pin plug (the one to which the sensor plugs).
Any ideas?
Does it affect the heater? Seems to blow hot all the time...
As stated above... Check the wiring ;)
I have the same problem! And yes, if you have climate control it does have an effect ::)
