NCDC 2013 Security Codes ?
Started by Big_Al, 26 February 2011, 00:10:29
Big_Al
just got a 2000 facelift model with NCDC 2013 fitted.  If the battery is disconnected do you need codes to get it working again. Previous owner did not know what i was talking about when iasked if he had the CD/radio codes. also cant see a procedure in the manual so thinking there are possibly no codes for these models ?
anyone know for sure ?   regards, Big Al ::) ::)
Whenever I've disconnectd my battery everything has worked instantly. I "think" you only need the codes if/when you depair/remove either item ... its all something to do with canbus but I don't know ... TB or DaveDND will/can explain I expect !!
You can disconnect your battery to your hearts content - the security on those works by keeping all parts of the system together, rather than checking for power removal.
Big_Al
QuoteYou can disconnect your battery to your hearts content - the security on those works by keeping all parts of the system together, rather than checking for power removal.
Thats that sorted then .     Thank you TB :y :y :y
