Author Topic: NCDC2013 Wiring  (Read 2053 times)
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
NCDC2013 Wiring
« on: 26 February 2011, 01:05:58 »
I have an idea...... run for cover!
Anyone got the complete list of colour codes, pin numbers & what they do for the wiring on the back this? Bose equipped if it makes a difference (If it does, I'd like both options pls)
Don't worry, I won't come looking if there's a big bang  :D
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
    • 530D M Sport, 330i Coupe
Re: NCDC2013 Wiring
« Reply #1 on: 26 February 2011, 02:02:27 »
All listed on a sticker on the Unit. speaker outputs are just re-routed to Bose amp via Bose loom if fitted. Obviously the unit is tweaked by Tech II for the different outputs levels required for a Bose setup.
Lampynoiseboy
  • SE Essex
Re: NCDC2013 Wiring
« Reply #2 on: 26 February 2011, 02:21:36 »
Mines missing the sticker, or at least most of it  >:(
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: NCDC2013 Wiring
« Reply #3 on: 26 February 2011, 08:08:02 »
hows your german and is this any good ?
Re: NCDC2013 Wiring
« Reply #4 on: 26 February 2011, 08:16:42 »
I can't print to PDF from TIS (Win7 problem), but its there. Accurate and definative.
If this is an upgrade, you need to tweak the wiring at display end as well.
If its an upgrade from ccr2006, I did it on a Traffic Master loom (to save car loom, plus its easier). I can look at that loom next week, and tell you the wiring moves/mods.
Lampynoiseboy
  • SE Essex
Re: NCDC2013 Wiring
« Reply #5 on: 27 February 2011, 19:27:56 »
Hmmm, Google's German is better than mine, I'll give it a go, thanks
It's not an upgrade, it's an experiment, that's why I need the 36-way loom (or ex-loom :-/) as we said saturday
Cheers for the advice btw
Win 7 not print to PDF at all?
