memory seats
Started by miggy, 07 March 2011, 12:17:08
miggy
Is the Omega CDX pre wired to fit memory seats from an Elite, if so where is the pre wired plug, most things are pre wired but cannot find the plug for the memory seats, it should be a 20 pin male??
Any of you guys know or done this seat swap before.
If the memory seats were not factory fitted, the loom will be missing. Not easy to retrofit for the full memory function.
The above comment includes Elites that were factory fitted with the Sports Pack.
miggy
QuoteIf the memory seats were not factory fitted, the loom will be missing. Not easy to retrofit for the full memory function.
Cheers TB, is there a way i can at least get forward, back and height motion, i dont really need the memory
miggy
All done now, took me most of the day but memory now also working but altering the wiring layout. :y :y
To answer your previous Q, as you have found, you just need to provide 12v and 0v to the right wires.
