Author Topic: No spark, its doin my head in.  (Read 2894 times)
harveycr
  • Port Talbot
« on: 14 March 2011, 13:12:04 »
no spark at number 1 cylinder. Anybody have any ideas. Could it be a sensor. I have racked my brains.  spark on number 4 but not on number 1. Ruled out leads and plugs. Thanx guys i have run this before on here but its doin my head in. This happened when i was driving normaly i could feel the miss as soon as it happened.  ;D
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: No spark, its doin my head in.
« Reply #1 on: 14 March 2011, 14:18:52 »
you say you have ruled out plugs and leads ? how did you do this ? do you get a spark when plug is put into a different lead?  also do you get a spark if No1 lead and plug is put into another position in the dispack? also try a known good lead and plug into No1 on the dispack, it has to be something to do with either leads, plugs or dispack i cant see anything else stopping just No1 plug not to spark  ;)
but could be wrong  :-?
« Reply #2 on: 14 March 2011, 15:30:09 »
might help if you said which engine you have  ::)
« Last Edit: 14 March 2011, 15:30:27 by tunnie »
fiend61
  • york
  • each to their own
« Reply #3 on: 14 March 2011, 16:00:29 »
yup that as well  :-/
but when he said he had eliminated plugs and leads i assumed it wasnt coilpacks  :y
« Last Edit: 14 March 2011, 16:01:10 by fiend61 »
« Reply #4 on: 14 March 2011, 16:08:57 »
Indeed, but 2001 plate says to me it must be DBW engine  :-/
Or its a very late 3.0...
« Reply #5 on: 14 March 2011, 18:27:11 »
fiend61
  • york
  • each to their own
« Reply #6 on: 14 March 2011, 22:23:44 »
hmmm just read that previous post
know i am confused i :-/ :-/
« Last Edit: 14 March 2011, 22:24:02 by fiend61 »
harveycr
  • Port Talbot
« Reply #7 on: 15 March 2011, 19:24:26 »
right lads, i hsve a 2001 V6 2.5. I have tried the number 1 lead in number 4 and i have a spark when i put the same lead and plug into number 1 i hae no spark. yhe car seems to run ok but for the miss in niber 1. When i tried a different DIS pack the faut is the same. I have changed the near side head gasket so i will re check the timing. Could anybody have any idea. I have booked it in for i diagnostic but im not holding my breath, Cheers for your patience guys.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #8 on: 15 March 2011, 19:30:30 »
should be able to paperclip test it then if its a 2.5
