Author Topic: Dash Display problems  (Read 2199 times)
Nickh
« on: 15 March 2011, 21:33:22 »
I have a '53 2.2 GLS, which has the basic Dash Display unit fitted . . is it a TID ? It looks as though it has two horizontal screens but only the top one displays anything.
Apart from the missing pixels the temperature is showing anything between -50C and -10C. I've replaced the outside air temperature sensor but this has had no effect.
Is the display knackered or is there some other "brain" driving the Display unit which needs attention ?
Also . . .
I've now been supplied twice with a radio mast with a thread too small for the base unit on the roof. The Vauxhall dealer stated that there were two sizes one 3mm and a 4mm or 5mm thread. The common one is the smaller of the two, and guess which one's I now have ? Does anyone out there know the correct spec of the lasrger of the two . . and where I can get one ?
Thanks,
Nickh
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Dash Display problems
« Reply #1 on: 15 March 2011, 21:52:55 »
firstly have you changed outside temp sensor for a known working one?
if it is good check big black connector which lives behind passenger side bumper up towards the headlight also wiring for signs of chaffing etc  :y
dont know about mast though  :-/
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
« Reply #2 on: 16 March 2011, 09:08:48 »
Also . . .
Thanks,
Nickh
Correct me if I'm wrong, but isn't the radio "mast" in the rear screen? Roof is GSM? Unless you have an estate.....?
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
Nickh
« Reply #3 on: 16 March 2011, 22:00:38 »
Fixed !
It seems I was a bit too premature with my assessment of the new sensor . . the following morning I got in the beast, and "Lo . . and Behold" 10.5 degrees C ! Seems that the system needed a bit of "down time" to sort itself out.
Oh and yes I do have the Estate version . . still not got the right size mast. I'm told on good authority that the thread is 6mm.
Thanks for the helpful advice though , , I'm sure I'll have more problems for y'all.
Nickh
« Reply #4 on: 17 March 2011, 00:06:31 »
Fixed !
Nickh
 :o :o Where do you live? the South of France.... ::) ::) ::)
« Reply #5 on: 17 March 2011, 09:25:28 »
Fixed !
Nickh
According to my (not-so) local news, were were 18C all day on Tuesday :o
Lampynoiseboy
  • SE Essex
« Reply #6 on: 18 March 2011, 23:45:43 »
Not here it bl**dy wasn't, nearly needed my thermals again!  :(
Nickh
« Reply #7 on: 19 March 2011, 10:19:13 »
Yep . . Tsunami's and techtonic plates not with standing I do live in the south . . Somerset !
I'm happy with the current indications . . they are a lot closer to reality than -45C !  8-)
Thanks,
Nick
