Author Topic: head light adjusters  (Read 2409 times)
greenman
  • greenock
« on: 29 March 2011, 19:34:29 »
Looking at previous for above.Mine seem to be manual? Is it possible the adjusters can snap in these.Mine are far too low.Turned for ages but no movement.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: head light adjusters
« Reply #1 on: 29 March 2011, 19:38:10 »
should hear motors moving if doing it with engine off, if not check fuse.
Solar charger fitted.
If not Broke dont fix it..
    • E250 Est / Elroq
« Reply #2 on: 29 March 2011, 19:50:04 »
yes, self levelling, and aim are 2 very different things, yes they snap.
(and no, you wont hear a motor for those  :-X)
does the reflector rattle round the lens?  if so, you need new adjusters - see sticky in parts for sale.
« Last Edit: 29 March 2011, 19:50:33 by jimbob »
Jezzer
  • Herts
« Reply #3 on: 29 March 2011, 19:50:07 »
Check to make sure your Adjuster aren't US!
Common issue on older Migs.
Plenty of posts on the Forum for 'how to fix'
I have had the same, you can replace the bulbs, try Osram Nightbreakers £30 approx, I fitted 'Halfords Brilliance' (£20 by-one-get-one-free) makes a huge difference.  :y :y
greenman
  • greenock
« Reply #4 on: 29 March 2011, 20:13:25 »
Adjusters must be knackered.Already fitted nightbreaker plus.Probably see the difference when the adjusters are sorted out.Thanks again.
Jezzer
  • Herts
« Reply #5 on: 29 March 2011, 20:19:02 »
As a temp fix, I took off the grill and lowered the bumper.
Then unscrewed the lower bolt supporting the Headlights and fitted a 3mm rubber washer behind the bracket to lift the lights up slightly - made big difference - and it passed the MOT!
But - Main Beam interfered with low flying aircraft   ;D;D
Since replaing the adjusters, took washers out - all back to near normal  :y
greenman
  • greenock
« Reply #6 on: 29 March 2011, 20:45:16 »
Do you need 2 per headlight.Side to side and up and down?
  • Online Online
« Reply #7 on: 29 March 2011, 20:50:06 »
It's just the up/down that fail so a pair will do both headlights.  :y :y :y
greenman
  • greenock
« Reply #8 on: 02 April 2011, 16:17:20 »
Aluminium adjusters ordered Thursday,arrived today,fitted today.Problem solved.Top part,top service.Only need to line them up..
