Vauxhall Diagnostic OBD 10 pin to 16 pin Adaptor
Started by chelski, 03 April 2011, 21:33:47
chelski
Vauxhall Diagnostic OBD 10 pin to 16 pin Adaptor Cable
high does any one know if i can use the above on a omega,b so you can use a normal  code reader another words make the reader work on tech 2 cars i know the paper clip test but want one that can clear, reset codes also there is a  OBD2 Tech2 USB Diagnostic Tech Opel Vauxhall Interface vier laptop and cd do they work
many thanks Darren
chelski
hi is that no as in only the snap,on will work
many thanks
Thats a no in that you cannot use an OBDII scanner or a non OBDII car, adapter or not.
chelski
ok do you know of any that work on tech 2 does the usb one work vier laptop
Without any kind of punctuation, I'm not sure I understand your post?
If you are asking what code reader you need, see the post about it Maintnence Guides.
chelski
what i am asking is which code reader works on omega's that does not cost thousands
Quotewhat i am asking is which code reader works on omega's that does not cost thousands
See that post in FAQ section, which says which works with which cars (later Omegas are OBDII)
chelski
i see now, this one is 1999 t reg manual elite estate quite rare in elite and petrol i believe may be wrong but have not found any manual elites in petrol
Quotei see now, this one is 1999 t reg manual elite estate quite rare in elite and petrol i believe may be wrong but have not found any manual elites in petrolĀ
Rare, no.  Less common than autos.
See that post in FAQs for your code reader options (illegal ones aren't listed there)
Quote.... but have not found any manual elites in petrolĀ
because they're a car that should have 2 pedals  ;) ;) ;)
chelski
i dont no of any illegal ones wont go down that road try and find a manual elite in petrol i have only ever come across 1 diesel elite on a/trader thats a manual
So look at that post in FAQ that descibed the common code readers for Omegas...
