Author Topic: Outside temperature 50 degrees ?  (Read 3003 times)
Dubious
  • Nearer Swindon than Brisbane
« on: 22 March 2011, 19:38:23 »
All of a sudden, the temaperature reading in the conputer console is reading about 50 degrees (it still changes a bit). I assume this means that the external sensor is wrong. Should I worry (apart from the climate control not working) - does this affect engine performance ?
Thanks.
Re: Outside temperature 50 degrees ?
« Reply #1 on: 22 March 2011, 22:07:50 »
No
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #2 on: 23 March 2011, 20:26:15 »
My outside temp has been showing 65 degrees for at least a couple of years, but it doesn't affect the air con / climate control - they're nothing to do with each other. (2.5 pre and mini facelift versions only)
« Last Edit: 24 March 2011, 10:15:57 by Tick_Tock »
Omega 2.5 V6 Facelift Estate.
« Reply #3 on: 23 March 2011, 20:30:19 »
.... but it doesn't affect the air con / climate control - they're nothing to do with each other.
but they're connected on later facelift cars though.  ;) ;)
Dubious
« Reply #4 on: 23 March 2011, 21:29:33 »
Thanks for the replies, It does affect the climate control - that's how I noticed in the first place.
Is it much of a job to change the sensor ? - can't immediately see it in Haynes. (But my Haynes is pre-facelift so mine is presumably different in that respect.
« Reply #5 on: 23 March 2011, 21:36:12 »
your sensor sits under the front lip of the bumper in the middle, but check the next connection back in the loom as it seems that this also gives problems.  ;) ;) Sensor just clips into the bumper & plugs into the loom ...... easy! :y
« Last Edit: 23 March 2011, 21:37:01 by Andy_B »
    • E250 Est / Elroq
« Reply #6 on: 24 March 2011, 07:45:02 »
As stated - Facelift cars use this sensor, prefacelift - its consmetic.
2 mins tops, dead easy to change as per Andy.
and only about £6 from Vauxhall, and will be in stock.
Taximan
  • Lincolnshire
« Reply #7 on: 26 March 2011, 21:38:50 »
Hi, I had similar high temp readings the first day above freezing last December. The glitch lasted for a few days then back to normal....still OK...mystery ???
Sorry not much help to you.
Regards,
Taximan.  :y
Jezzer
  • Herts
« Reply #8 on: 27 March 2011, 15:41:18 »
Just had a similar experience on my 2000 2.0 16v 20XEV Engined CDX Auto.
I was told that the sensor 'did not' effect the Climate Control (Heating or Cooling)
Well I can confirm 100% it does! (well on my car it did)
Although mine is a 2000 Reg, it is 1999 spec....
I put in a new one after the temp reached 36 Degrees and climbing....
The Heater is now much better and the air con too  :P
I also think the car is running smoother, seems to be more economical  ::) probably a pure coincidence though  :y
Dubious
« Reply #9 on: 28 March 2011, 22:22:01 »
Thanks for the follow-up replies. I'll have a look in the morning.
Dubious
« Reply #10 on: 06 April 2011, 21:55:52 »
All fine now - thanks everybody.
The sensor fits sort of below the washer bottle, right in the middle - easiest to find by feel. It clips in, and was a little nerve-wracking wiggling it out.
« Last Edit: 06 April 2011, 21:56:46 by Dubious »
Page created in 0.167 seconds with 20 queries.
