Navigation DVD eject by itself...
Started by Dany, 08 April 2011, 22:01:21
Dany
Why my NCDC 2013 eject the navi DVD by itself all times?? Always when I start the car (when all is "cold")... Looks like the headunit eject the DVD until it heat a little bit...
Usually a sign the laser is getting "tired" .. are you using an "original" disc or a computer burned (copied) one ??  Copied discs knacker the laser fairly quickly, and then even using a "proper" disc the problem occurs.
I found a copied disc in my car when I bought it, I have replaced it with a genuine disc but it still ejects until the unit has warmed up a bit, then works fine.....
laser is damaged .. but not wrecked .. :)
Dany
I don't really know to be honest... But he looks like an original one (V.2009)! And I never used other discs in this player except the navi one...
So if it's the laser, what do I have to do now??
QuoteI don't really know to be honest... But he looks like an original one (V.2009)! And I never used other discs in this player except the navi one...
Either live with it .. or replace the laser  .. there is a thread around about that .. I'll see if I can find it
EDIT ...
Here you go ... might help .. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1302008796
mindaz
 NCDC 2013 reads only CD discs , not DVD
Vauxhall/0pel 0mega 2.5 , 2002 , CD
Dany
EDIT ...
So you think it's just the lens need a cleaning?
QuoteNCDC 2013 reads only CD discs , not DVD
I know that, not DVD video, but the navi discs are DVD! It's the high player that I'm talking about, not the magazine.
EDIT ...
The cleaning may help but it won't cure whats already broken.
Definately not a DVD transport, CD Only
Dany
And if it's broken and need a replacement, where can I find new parts? The new laser will need soldering or just a plug and play item?
http://www.lasertrader.de/english/
You can buy just the laser unit or the whole transport.  :y
Dany
Obviously just the laser unit available now... I will try to clean it when I have the courage lol
wakeyomega
#10
Hi Dany
Cleaning is the simplest procedure. Mine is still going strong since the clean I mentioned in my previous post and it had exactly the symptom you described, so its worth a go.
If / when I do eventually need to fit the laser unit I bought, I'll post a how to with pictures.
Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
QuoteObviously just the laser unit available now... I will try to clean it when I have the courage lol
Have a browse of the site, I think you'll find they can supply most of the upper and lower Mechanisms for most units.
Dany
#12
QuoteHi Dany
Pat
Do you used water to damp your coton bud?? Dave not recommand alcohol...
The reason of my laziness is that the ISO connector behind the headunit is broken in two parts, so it is no longer clipped on the cage and it's very very difficult to remount it! The last time, I had to remove the glovebox to pass my hand and plug properly behind!
So if you have a spare 3 sections ISO connector by the way...  ::)
AH! The website works better in German mode lol. Anyway the only parts that still available are the laser bloks...
Nope, click on 'Mechanisms' on the left then Opel and scroll down about two thirds of the way. That's the Nav drive unit complete. Just don't look at the price!
Dany
Yeah I have seen that but the parts are out of stock and no more available, just the laser so...
