Loom to drive a CID. Parts needed
Started by RobG, 17 April 2011, 16:24:31
One for The Boy or VXL V6. What bits are needed to make up a loom to drive the CID :-/
zirk
Best to make it utilising a Trafficmaster loom. Will also need the 12 pin RGB plug and some loom, quite difficult to locate the plug but they can be had from ebay.de or you can use a CDC2 autochanger plug.
QuoteOne for The Boy or VXL V6. What bits are needed to make up a loom to drive the CID :-/
Wires.  :y
Sorry Rob - couldnt resist. :D ;D
Wires.  :y
;D
QuoteBest to make it utilising a Trafficmaster loom. Will also need the 12 pin RGB plug and some loom, quite difficult to locate the plug but they can be had from ebay.de or you can use a CDC2 autochanger plug.
Got it :)
