HID conversion wiring.
Started by albitz, 16 April 2011, 11:43:47
Im hoping to put HID,s on my car today. Istr Elite Pete saying the wiring is very easy. Just two wires ? Anyone know more precise details ? Tia. :y
Wont be doing it today. Ive snipped the wrong two wire plugs off the Elite loom, and Im at work so cant do anything about it until after dark.Tw*t. ::) :(
Albs, all you need is the plug that goes to the ballast unit. Snip it back as far as possible, should be a yellow cable and a brown one. These two splice into the yellow & brown on your car. Don`t forget to swap your level motors over
Cheers Rob. :y..........dunno what you mean about the level motors tbh. :-[
Back of the HID`s is the ballast box, next to it is a black oblong plastic box with one end curved/rounded with an electrical connector on it. That`s the level motor. Remove connector, turn motor through about 90 degrees and pull out. Both of these need to be replaced with your level motors
Because the motors on the HID`s are electronically controlled by the HID ecu & level sensors therefore they won`t work with your lighting loom hence the need to swap them over ::)
So should I leave my standard light switch on the car and retain the option to adjust the light with the knurled wheel thing. ?
#8
Yep, hence the need to swap the motors over. If you want the HID`s to be self-levelling it`s a hell of a job as you would need the HID ecu, both level sensors, all the loom (virtually impossible) plus a Tech II chat to program your MID for HID`s.
The level motors are just a swap out & plug & play
Didnt know that Rob - cheers. :y..........Jammy will be happy.looks like I have a headlight switch for him after all. ;D
QuoteDidnt know that Rob - cheers. :y..........Jammy will be happy.looks like I have a headlight switch for him after all. ;D
Job done. :y cant wait to have a wee drive in the dark to see how much better the lights are. :)
QuoteJob done. :y cant wait to have a wee drive in the dark to see how much better the lights are. :)
:y might have to re-adjust them
Probably adjust tyre pressures - same effect. :y :D ;D
The difference is like night and day - literally. I think they need to be adjusted down a tad though. Main meam is lighting up the tree tops. :)
