Low washer fluid warning
Started by Vamps, 10 May 2011, 23:16:19
Even when full and all works perfectly... ::) where do I start?...... :)
QuoteWith the sensor ::)
Thank you, but could not find it in the boot..... :P :P :P
I think it's in the end, o/s iirc :-/
It's a basic float gauge if I remember correctly and is easy enough to change out :y
In the back of the washer bottle. Take sensor out, cover your feet in washer fluid, clean sensor, push back in, refill.
8-)
QuoteIn the back of the washer bottle. Take sensor out, cover your feet in washer fluid, clean sensor, push back in, refill.
8-)
Thanks, so having just filled it up it might be best to use some of the water before cleaning...... :y
8-)
...........and if it still don`t work, I got a couple here :)
8-)
Thanks Rob, will take a look at the weekend... :y
