Author Topic: Programming keys  (Read 1981 times)
Programming keys
« on: 11 May 2011, 21:57:19 »
Just a quick question here... If you get hold of a replacement key remote and put your blade and immobiliser chip in, can you sync the remote in the normal way or does it have to be physically programmed first?
Re: Programming keys
« Reply #1 on: 11 May 2011, 22:19:35 »
.... or does it have to be physically programmed first?
Yes.  :y
« Reply #2 on: 11 May 2011, 22:40:57 »
Yes.  :y
That was what I thought... I'll just get mine refurbished one at a time then........
......... Martin Imber to the rescue! ;D ;D ;D
One works, the other doesn't, although it may just be a flat battery, but both have slightly loose battery holders and a bit of cardboard behind them to hold them in place ::) ::)
And I've got a Vx invoice for 2 new keys not that long ago :-X :-X :o :o
« Reply #3 on: 11 May 2011, 22:46:35 »
Yes.  :y
I have the same problem with my spare key/fob. If I try to use it, nothing happens except the led stays lit. If I then spit the key & remove the battery to turn the led off, it the fob will generally work as it should  :-? :-? :-? until the next time I want to use it.  :(
« Reply #4 on: 12 May 2011, 03:18:47 »
Yes.  :y
Fob itself was £35 from vx last I looked. Couple of years ago now though.
« Last Edit: 12 May 2011, 03:20:31 by chrisgixer »
« Reply #5 on: 12 May 2011, 03:21:58 »
Yes.  :y
They've done away with the LED though. Which I guess makes them Vectra fobs?
« Reply #6 on: 12 May 2011, 05:24:43 »
Yes.  :y
Im trying to work out how spitting helps. :-/
 :D ::) ;D ;D
« Reply #7 on: 12 May 2011, 07:56:53 »
Last 3 button alarm fob I bought, last year, was £27, which is what I would do if I didn't have the capability of repairing my own.  Would need to check, but thought mine did have the pointless LED...
« Reply #8 on: 12 May 2011, 08:49:42 »
 :D ::) ;D ;D
it just makes me feel better!  ;) ;) ;) ;)
when that doesn't work I spLit it  ;D :y
