another one for davednd
Started by fiend61, 20 May 2011, 17:40:42
fiend61
is it true that the cr 2006 once having lost power you can only input the radio code but not the cd code??  :-/
i have one at the moment that allows me to code the radio but cd is dead, if you press cd the screen goes blank then it reverts straight back to radio, or am i being stupid (once again)  :-/
Dave DND
#1
CCR2006 does not need a seperate CD code and you only have to enter the one code to get the unit to work if you have power disconnected !!
If its asking for one by saying "CDC-SAFE" then you have an internal software fault.
details here
http://www.dndservices.co.uk/ccr-2006-e.html
PS, screen going blank and reverting back to radio would indicate a serious changer fault - Jammed or even FUBAR   :'(
Radio & Decoding Technician
fiend61
ok cheers dave
looks like it is fubared then  :(
put cartridge in with a cd - press cd and radio mutes, radio station goes from screen but then nothing for a few seconds then reverts back to radio  :(
it also wont eject either  :(
bit of a bummer really  :(
henryd
Quoteok cheers dave
The original in mine went the same way,could'nt eject the cartridge and "cdc safe" showing,managed to get another from a member here
other rides
Dave DND
QuoteThe original in mine went the same way,could'nt eject the cartridge and "cdc safe" showing,managed to get another from a member here
CDC-SAFE is about the only fault on these that can still be fixed - if you still have the unit, it may be worth getting it looked at, as could be "sellable" once repaired
fiend61
QuoteCDC-SAFE
pity mine doesnt even show that  :'( :'(
henryd
sadly I don't :'(
other rides
