DAB radio
Started by MV6Matt, 17 May 2011, 19:35:36
MV6Matt
Have one at home - when I move it round the house and re-plug it in it picks up the time straight away.
Any reason my Car one won't pick up the time in the same way?
Matthew
(thanks Ian)
Dave DND
Internal software settings of the car stereo - probably nothing you can do about it.
Radio & Decoding Technician
www.dndservices.co.uk
2woody
have you got an antenna on the outside of the car like you'd expect for the FM radio ?
MV6Matt
Quotehave you got an antenna on the outside of the car like you'd expect for the FM radio ?
Hi Stu,
Yes, I changed from the hopeless windscreen string and went back to external Roof mounted - a JVC DAB aerial for the JVC DAB H/U.
Why you ask?
Matthew
(thanks Ian)
Martian
Do you have an option to enable network time in the setup menu?
If not, then as Dave says it's more than likely a software restriction.
MV6Matt
QuoteDo you have an option to enable network time in the setup menu?
Absolutely no idea! I'll have to see if the incomprehensible manual can shed any light.
Thanks for the suggestion :y
(thanks Ian)
