Author Topic: Whats this wire for.  (Read 4568 times)
alfie
  • Gwent
    • Mondeo Ghia estate tdci
« on: 14 May 2011, 18:45:23 »
Hi,can anyone tell me what is the wire that comes out of the top of the timing cover for,it's secured by a bracket fitted to driver side of the engine .(male/female connector). I'm having trouble with this wire,sometime's the motor fails to start,as if no fuel getting through,disconnect this wire,reconnect and the motor will start.
It's driving me mad trying to sort it,any help gratefully received.
                Alfie.
Re: Whats this wire for.
« Reply #1 on: 14 May 2011, 19:18:42 »
Either knock sensor or EGR.
alfie
  • Gwent
« Reply #2 on: 15 May 2011, 07:41:41 »
Hi,thanks for that  are they easy to fix/replace.
« Reply #3 on: 15 May 2011, 09:55:05 »
If you can identify which - a picture is worth 1000 words ;) - but ultimately both can be repaired...
the alarming man
  • medway kent
    • disco V8
« Reply #4 on: 15 May 2011, 12:17:04 »
would be best too post a pic :y
alfie
  • Gwent
« Reply #5 on: 15 May 2011, 14:20:55 »
How do I post a photo,
« Reply #6 on: 15 May 2011, 14:25:34 »
Have a look here mate - http://www.omegaowners.com/forum/YaBB.pl?num=1215723122
alfie
  • Gwent
« Reply #7 on: 15 May 2011, 20:03:38 »
Sorry for the delay in the photo's,bit of a problem in popsting on this site.Loaded onto photo bucket ok,but doing something wrong when trying to upload onto here,(where's the share button).
Anyway removed the plastic cover from engine to expose where the cable go's,no luck there it go's into the loom and do'es not seem to appear again.
Try again tomorrow to get some photo's,cause right now I need a beer or two .
        Alfie,
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #8 on: 15 May 2011, 20:37:30 »
photobucket  hover over image then copy the IMG code, then paste the code straight onto the forum  :y
alfie
  • Gwent
« Reply #9 on: 17 May 2011, 20:14:42 »
Still can't get the photo from photo bucket onto the forum,followed the guide,but it will not upload.
I'm using windows 7,is that any different to to xp?
Anyhow the starting problem is getting worse so my usual mechanic is going to plug his knowall puter in,and check it out for me.
            Alfie
alfie
  • Gwent
« Reply #10 on: 19 May 2011, 03:47:47 »
Hi, well that wire had nothing to do with the starting problem,thats down to the usual suspect again.
Got it checked out last night,and code 19 again,crank sensor!.
This was replaced about 18mths ago.Vauxhall parts as well,this time it's going to be cheapo bit's.
This must be the most high maintenance cars that I've ever owned,and if it wasn't for the help of the folk on here,it would have been history long ago.
« Reply #11 on: 19 May 2011, 18:53:11 »
Follow the 'OOF' routing for the wire, see Maintenence Guides :y
alfie
  • Gwent
« Reply #12 on: 22 May 2011, 20:05:22 »
All sorted now,only cost £110. Hope this lasts longer than the last one.
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #13 on: 24 May 2011, 14:03:03 »
You'll be changing it again soon then, unless you're very lucky, it's recommended on here that you only use genuine crank sensors. They only take 10 minutes to fit and do you have a trade card? A lot cheaper if you do  :y
Maybe the last (genuine) crank sensor that was put on wasn't routed away from heat sources properly, a cause of early failure
« Last Edit: 24 May 2011, 14:04:33 by jmdavies »
alfie
  • Gwent
« Reply #14 on: 24 May 2011, 17:09:16 »
Hello Johnny,the guy that do fixe's my car works for a main dealer , a very fussy guy that likes to do a good job. He's done a lot of work for me over the last few years,always first class and always gives me a loaner(Volvo C70 D5 this time very very nice) not always as cheap as I've like but reasonable.
The part cost was £68,VX cost was £84,I should have gone for the small extra cost,but was out of contact (no phone signal vanning on the banks of the river Wye in Herefordshire).
Was these prices compatible ,to your costing.
         Alfie in Ebbw.
