Electric window auto close when dead locking
Started by Omega AOS2002, 21 May 2011, 18:26:11
Omega AOS2002
Have a question, has anybody had this problem.
Motor OK as window opens and closes normally when using the switches.
Have checked wiring and all ok. Reset one touch open and close.
When deadlocking with windows open, all close but not the n/s front and will not close unless closed by switch.
Any help welcome.
Have you tried a "resynch" ??
tells you how in the owners manual .... :)
Osprey
The owners manual is available on this forum in the "Omega Common Issues and FAQ" section.   :y
I feel like a military academy. Bits of me keep passing out.
Omega AOS2002
Thanks for the suggestions.
Will try tomorrow.
Omega AOS2002
Reset 4 times.
The passenger side front window will not auto close on deadlocking.
All others close ok.
QuoteReset 4 times.
will this window auto close & detect an obstruction at other times?  :-/
Omega AOS2002
It auto opens and closes ok all the time using the door switch or drivers door switch.
have not tried obstructing it on closing
Dave DND
Try it with the window open by only an inch or so -
If the window moves, you have an obstruction somewhere lower down.
If the window does not move, it could be the control box relays, or the wiring to the door that is as fault.
Unlikely to need resynching as the others work.
Radio & Decoding Technician
www.dndservices.co.uk
Omega AOS2002
Hi Dave
Have tried from approx 1 inch open to fully open will not auto close on deadlocking.
Can only think motor as it doesn't move at all.
QuoteHi Dave
Can't see how it can be the motor as it works ;)
Best guess is a wiring fault  :-/
Dave DND
QuoteHi Dave
Definately not the motor !
If the window does not move, it could be the control box relays, or the wiring to the door that is as fault as previously suggested
ISTR that if the window works from the switch the the issue is with the control box. Might it also be worth unplugging then reconnecting the door loom on the A post? :-/
Omega AOS2002
Have unplugged and reset window and still does not close so could be a broken wire.
Dont know which cable that could be affected and to trace and check each one could take several hours.
So if someone knows the colour code of the cable to try first it would be of great help
