stereo
Started by bored bigyin54, 17 June 2011, 15:32:30
bored bigyin54
can anyone tell me why the cassette player can be repaired i take the tape out and the inside drops down so i cant put a tape back in its out off a 98 2.5 elite thanks
Couldn't understand a word of that, but if you are suggesting your stereo is bust, you can try stripping it down to check, or get another ccr800 (dirt cheap) from breakers here.
bored bigyin54
no its just the tape player part wenn i can get a tape in it plays fine
Quoteno its just the tape player part wenn i can get a tape in it plays fine
Is it a CCR800? They are normally robust.
Take it apart, if its not obvious, or difficult fix, just get one from the likes of Darth Loo-knee or Elite Pete etc. CCR800 is common and cheap, not really worth messing about with TBH.
Dave DND
Please try to construct a question carefully, enclosing enough model information of the item in question and what you are trying to do, and then, and only then, can we try to work out what you are babbling on about and try to assist.
Like TB has said, I cannot understand what you are trying to ask either
Radio & Decoding Technician
www.dndservices.co.uk
I_want_an_Omega
QuotePlease try to construct a question carefully, enclosing enough model information of the item in question and what you are trying to do, and then, and only then, can we try to work out what you are babbling on about and try to assist.
Like TB has said, I cannot understand what you are trying to ask either :-/
Thought it was just meĀ  :y
bored bigyin54
ok wenn i take the tape out i can put a new one in
bored bigyin54
i mean to say cant put a tape in
fiend61
as said before,  nobody knows what radio you have in the car !!!!!!!!!!!! so nobody can really advise!!!!!!!!!!
as TB has said if it is a ccr 800 then you have two choices take it out and attempt a repair or obtain a replacement working unit with code from elsewhere  :y
bored bigyin54
it has fixed itself working now as normall
