battery help 12volts
Started by ninjapirate, 25 June 2011, 21:04:21
ninjapirate
i just replaced all the batteries on boat, it has 3 massooove ones, one per engine and one domestic, it has a built in charger that in the past ive always just left charging, but with new batteries is it better to run the domestic one down, then recharge? i think it makes ure the engine ones are charged then switches to charging the domestic.
engines do have alternators.
thanks
'pirate
Dave DND
Unlike domestic rechargeable batteries that have a memory retention and require discharging every now and then, lead acid / gel based batteries tend to function better over time if the full charge is maintained in them.
Radio & Decoding Technician
www.dndservices.co.uk
ninjapirate
QuoteUnlike domestic rechargeable batteries that have a memory retention and require discharging every now and then, lead acid / gel based batteries tend to function better over time if the full charge is maintained in them.
why thankyou sir, i shall leave the charger on when im on here. turning shore supply off while im not on it for now.  :)
