Washer bottle level indicator thing.....
Started by Vamps, 03 July 2011, 21:42:03
Does this have a circuit board in it? (on the washer bottle) if so mine is broken, very broken..... ::) ::)
Now I know it has not been working since the snow, not a problem, just that I have to tap the end of the stalk to get rid, hardly a problem....
My question is, can I just join the two wires together and bypass the whole thing?
Have you tried physically pushing the float switch down inside the expansion tank a few times with your finger Mike? Also take off the metal wing clip holding the tank & slide the tank inwards an inch or so until it comes free of its track & check that the multiplug is still firmly attached! If after all this you still have the 'check' warning, the float switch is goosed & a new tank is in order ::) The plug can be short circuited using a paperclip  :y
QuoteHave you tried physically pushing the float switch down inside the expansion tank a few times with your finger Mike? Also take off the metal wing clip holding the tank & slide the tank inwards an inch or so until it comes free of its track & check that the multiplug is still firmly attached! If after all this you still have the 'check' warning, the float switch is goosed & a new tank is in order ::) The plug can be short circuited using a paperclip  :y
Mike is on about the washer bottle Phil :D
:-[ Doh!!!!  :-[
Too much Gin & it, & a lung infection make Jack a (very) Dull Boy!! ;D ;D ;D ;D ;D ;)
Pop out the sensor, and clean it up (sometimes get gunked up with that white stuff).  Though if it was ice, its probably fubar, but easy enough to visually check.
QuotePop out the sensor, and clean it up (sometimes get gunked up with that white stuff).  Though if it was ice, its probably fubar, but easy enough to visually check.
The green circuit board is broken.....
QuoteGot one here £4 posted :)
PM Sent..... :y
Ah, replace then ;D
QuoteRob, you have funds...... :y :y
Just to confirm Mike. This what you`re needing
I do not know what is behind as all I got was a broken circuit board, the whole thing did not come out ::) ::) But it looks like what I want, and TB confirmed...... :y
Monies received, will be in the post tomorrow Mike :y
Don`t bust it putting it in :D
Thanks Rob, if it comes before the lakes I will seek professional help..... :y
It`s going 1st class, so wrap it in cotton wool and get it fitted at the meet ;D
