alternator
Started by tony2, 10 July 2011, 10:22:47
tony2
morning all, have a 02 2.6. alternator only showing charge as 12.4 even with everything switched on suspect on the way out ,question is will a 2.5 td alternator fit and be acceptical,this alternator is off a 2000 f/lift cheers tony
tango
the deisel alternators are different
12.4volt is a bit low but you say you have everything swithced on so the drain is causing the volatge drop
