Lost Radio Code
Started by cricketcat, 03 July 2011, 14:57:47
cricketcat
Hi,
I have just bought a P reg Omega 2.5 V6 CD and the dealer did not have the code for the CDR 500 Radio/CD fitted.  Does anyone know if I can get the code from Vauxhall and if so who to contact?
QuoteHi,
If you can be sure the radio was fitted at the factory then the code would be on the car's original 'Car pass' which also includes other codes for the immobiliser etc. Vauxhall dealers will charge  you from about £20 for it, but some charge somewhat more, you'll need the V5 & some form of ID.
Of course you could also contact DaveDND here ..... he does this for a living.  ;)
cricketcat
Thanks - I will have a word with my local dealer ans see how much they charge. :)
tonyyeb
As a guide for you, I was charged £26 by my local VX dealer back in November last year.... :(
blackviper90210
QuoteThanks - I will have a word with my local dealer ans see how much they charge. :)
As Andy B mentioned, unless you can be sure it's the original unit fitted when the car was built, Vx won't have the correct code.
Again, DaveDND is a sound bloke who is very helpful!  :y
AKA - Mr Bracket
russ0205
#5
I agree have been in contact with DAVEDND on here when i needed help and he is a top bloke, i would be very wary about gm dealer as at that age may not be the orig stereo and that means £25 down the tube.
Vx Garage in Darlington did mine, £25.00 Radio out, sorted and back before I had finished my coffee.....Top Service.... :y :y
cricketcat
I have had a look on e-bay and I can get a identical replacement unir - complete with codes for just over £15 - might be an easier way to as they just slot in.
QuoteI have had a look on e-bay and I can get a identical replacement unir - complete with codes for just over £15 - might be an easier way to as they just slot in.[/quote]
In theory....... :D :D :D
Dodger
#9
Provided it's got the correct code with it, or you are back to square one.....
Also, if you get the 'car pass' from VX, even if the codes on it are not the ones for the radio, at least you will have the immobiliser Number, & key number for future reference, so not entirely wasted...
My local VX dealer got me a replacement in 24 hours.... (paper printout)  and the proper card arrived to my home address 3 days later.. so may still be worth having .  :)
I always knew I'd inherit an estate, but I never thought this would be it!
Dave DND
Which make of CDR500 do you have ?
If DELCO, then let me have the 14 digit number engraved on the side, as I have just started doing these one via the net.
Radio & Decoding Technician
www.dndservices.co.uk
cricketcat
Good Point about the other codes - will get the card from vauxhall and if it turns out not to be the original unit will take you up on your offer - thanx to everyone for all the help
