Pass Codes
Started by Shackeng, 16 July 2011, 14:23:14
Shackeng
I have just received the pass codes for my new Elite. Am I right to be suspicious that the Key Codes and Radio codes are identical?
Shackeng
Dave DND
Depends on the stereo
If it was a NCDXXXX model that doesn`t need a code ?
Radio & Decoding Technician
www.dndservices.co.uk
Shackeng
QuoteDepends on the stereo
Sorry for the late reply Dave, I've been locked out for two days. I have an NCDC13, but why give a code if it doesn't have one, other, perhaps, than to try to justify the £21 they charge! >:(
Sorry, just seen this.
If you have an NCDC, the radio's pairing code is set to the car's PIN code, so they will be identical (assuming nobody has replaced the stereo).  The NCDC doesn't have a code 'burned in' by the manufacturer, like traditional units.
Hope that makes sense.
Shackeng
QuoteSorry, just seen this.
Thanks Jaime, so no code required when removing the battery. :y
Nope, not for radio :y
You just need to reset the windows and sunroof after battery disconnection :y
Shackeng
ajr3773
How do you reset the sunroof and windows. Sorry for hijacking but ive just fitted a new battery.
QuoteHow do you reset the sunroof and windows. Sorry for hijacking but ive just fitted a new battery.
See FAQ section :y
twiglet
Can't find anything in the FAQ or maintenance sections about reseting the sunroof. Am I missing something obvious?  :-/
twiglet
Quotehttp://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
Page 125 .. :)
Top man Nigel!  :y
Out of interest, after the battery has been re-connected will the sunroof do anything at all until the re-programming has been done?
