ccr 2006
Started by F1 9LFG, 24 July 2011, 13:30:26
F1 9LFG
Hi all,
I have a CCR2006 in my facelift cdx.
It's started to skip when playing CD's.
Brought a brand new disc today, still the same problem, it plays a few seconds, then stops playing for 10 or so seconds, then continues to play, less than 20seconds later it stops again, etc etc
Very annoying, assuming its a problem with the laser? is it a common problem? can it be cleaned at all?
Thanks   :y
Bionic
#1
Had the same problem with mine. It can be cleaned using any normal cd/dvd disk type cleaner that you insert like a disk.
By the way, even after cleaning mine absolutely refuses to play copies of any type. I do very high quality ones too and they will not play, just skip when the genuine ones play without problems.
Hope that helps.  :y
henryd
other rides
tango
are you using cdr's does it play genuine discs
if so try a diiferent make
Dave DND
Quoteare you using cdr's does it play genuine discs
NO !!  The CCR2006 is NOT COMPATABLE with ANY recordable discs
have a read of this
http://www.omegaowners.com/forum/YaBB.pl?num=1300229193
Radio & Decoding Technician
www.dndservices.co.uk
Indeed, playing any CDR does seem to cause permenent laser damage.
It would be hypocritical of me to say don't do it, but just accept the fact you will knacker it.
F1 9LFG
Quotehave a lookie here ;)   http://www.omegaowners.com/forum/YaBB.pl?num=1293577197
oh dear  :'(
seems i've fluffed it then, saying that, i've been playing cdr's constantly for a good year and i discovered today that it only 'skips' on tracks 1,2 and 3. the remaining tracks play out fine.... maybe its just the beginning of the end
thanks chaps
